03-09-2015
08:24 AM
03:40 PM
Hello.
I bought a 70D a few days ago and wanted to try the wi-fi function today.
I downloaded and installed the latest software for my camera from the Canon support site.
Im having the following problem with the software.
When i run EOS Utility I get the following message:
-To connect to the camera via LAN, some Windows Firewall settings must be changed. Do you want to make these changes?
I click yes and get the next message:
-WFT FirewallSettings has stopped working.
The next message i get after i click on close program says:
Could not change the Windows Firewall settings.
I tried adding the EOS utility and EOS utility 2 manualy, and allowed acces, but it still doesnt work.
08-23-2019 10:14 AM
Hey,
Follow these steps please :
> In the search bar of the Windows Taskbar type : Firewall
> Click on "Allow an app through Windows Firewall"
> Click on "Change settings" button
> Click on "Allow another app..." button
> Click on "Browse..." button
> Browse to this path : C:\Program Files (x86)\Canon\EOS Utility\ and choose "EOSUPNPSV.exe" file
> Check both "Private" and "Public" for the "Canon EOS UPNP Detector"
> Click on "Ok"
Best
Lynx
03-09-2015 11:02 AM
Not enough info but I will guess it is your firewall and not EOSU. You need to look there.
03-09-2015 11:41 AM
I cant give you more info than this picture:
03-09-2015 04:14 PM
I think i found the solution for my problem. I just chenged the language from Slovene to English and it started working.
After that i changed it back to Slovene and it's still working. I hope the program wont give up on me any time soon.
01-09-2016 10:45 AM
Really .. really thanx a lot .. Czech language works too .. I had the same problem ...
12-11-2016 10:36 PM
Hi, I have got the same proble with Utility 3.
I try to pair it with my EOS M10 in windows 10 but it always come up with error :''WFT Firewall Settings has stopped working'', May i know how you did with the language settings ? did you mean the OS language setting ?
thanks so much
03-08-2017 01:34 PM
Did you get any solution to this problem?
Im trying too and get the same error and do not find any solution to it.
Can you help me?
/Stefan
08-23-2019 10:14 AM
Hey,
> Click on "Ok"
Best
Lynx
06-04-2020 03:37 PM
It worked! Thank's
01-17-2022 06:35 PM
thank u so much it working ♥
