EOS Rebel T8i shows no focusing aids when using 2x Extender
wgander
My Sigma 150-600mm lens works fine with my camera but when I use it with the Canon EF 2x Extender there's no focusing aids on the screen/viewfinder. Is this a limitation of the Extender? Is there a way to see the focusing spots? Manual focusing at 2x is difficult without a tripod. I've been doing mostly wildlife photography.
4 REPLIES 4
wq9nsc
Your camera AF system is limited to working with a lens setup that provides at least a f8 aperture when wide open.  The 2X extender combined with the Sigma 150-600 results in an minimum aperture that is beyond the AF capabilities of your camera body.
Rodger
Would Canon 1.4 extender work?
wgander,
While some customers report no problems with autofocus, others mention it doesn't work in AF mode.
From Wiki[edia:
Some EOS bodies are unable to autofocus when the maximum aperture of a lens is smaller than f/5.6. Professional-level bodies are capable of autofocusing lenses with a maximum aperture of f/8, but only with the centre autofocus point.[5] With a 2× extender a 400mm f/4 lens would have an equivalent focal length of 800mm and a maximum aperture of f/8, in which case autofocus would only be available with professional bodies. With the same converter a 400mm f/5.6 lens would have a maximum aperture of f/11 and autofocus would be disabled.
You might want to read this archived article from Canon on using extenders:
https://web.archive.org/web/20190601165556/https://cpn.canon-europe.com/content/education/infobank/l...
Apart from reduced maximum aperture, another potential drawback of using Extenders is loss of autofocus. On most cameras, autofocus stops when the maximum effective aperture drops below f/5.6, irrespective of the amount of light available. However, there are some EOS models that allow autofocusing at maximum apertures down to f/8.
-more-
Steve Thomas
johnrmoyer
Whiz
Whiz
I suggest trying live view mode.
