12-16-2025
02:09 PM
02:13 PM
My Sigma 150-600mm lens works fine with my camera but when I use it with the Canon EF 2x Extender there's no focusing aids on the screen/viewfinder. Is this a limitation of the Extender? Is there a way to see the focusing spots? Manual focusing at 2x is difficult without a tripod. I've been doing mostly wildlife photography.
12-16-2025 02:26 PM
Your camera AF system is limited to working with a lens setup that provides at least a f8 aperture when wide open. The 2X extender combined with the Sigma 150-600 results in an minimum aperture that is beyond the AF capabilities of your camera body.
Rodger
12-27-2025 03:27 PM
Would Canon 1.4 extender work?
12-27-2025 03:46 PM
wgander,
While some customers report no problems with autofocus, others mention it doesn't work in AF mode.
From Wiki[edia:
Some EOS bodies are unable to autofocus when the maximum aperture of a lens is smaller than f/5.6. Professional-level bodies are capable of autofocusing lenses with a maximum aperture of f/8, but only with the centre autofocus point.[5] With a 2× extender a 400mm f/4 lens would have an equivalent focal length of 800mm and a maximum aperture of f/8, in which case autofocus would only be available with professional bodies. With the same converter a 400mm f/5.6 lens would have a maximum aperture of f/11 and autofocus would be disabled.
You might want to read this archived article from Canon on using extenders:
Apart from reduced maximum aperture, another potential drawback of using Extenders is loss of autofocus. On most cameras, autofocus stops when the maximum effective aperture drops below f/5.6, irrespective of the amount of light available. However, there are some EOS models that allow autofocusing at maximum apertures down to f/8.
-more-
Steve Thomas
12-27-2025 06:40 PM
I suggest trying live view mode.
