07-30-2024
08:03 AM
09:33 AM
I take vidoes of my husbands bands I have my camera and lens on auto focus but when the lights are bright it randomly unfocuses amd refocuses. If its alittle darker with the different color lights flashing i dont have this problem. The camera is either set on the "A" with a square around it or scn. Im assuming scn means scene?? But not sure how to change to different scenes or which one would be appropriate. Im new to this and could use some advice. I cant find youtube videos to help. Im also needed a wide angle lens because sometines thier really spread out (5 piece band) or im not able to get far enough away to get them all in. Can someone help me out please or point me in a direction for help?
07-30-2024 12:05 PM - edited 07-30-2024 12:06 PM
Diakara,
Do you know how to put your camera in Live View?
If you don't, the put your camera in one of the Creative Modes like M or Av or Tv. Press the little white button just above your LCD screen on the back right next to the Viewfinder.
Now press your Menu button. Your first set of tabs is in red and looks like a little camera.
It will give you about 5 sub-tab options. Scroll over to the 5th sub-tab. The third option in the list is called Continuous AF.
Disable that.
I think that will solve your problem.
As far as a wide angle lens, what lens are you currently using?
I have a T8i myself and I like it a lot.
Steve Thomas
07-30-2024 12:39 PM
Diakara,
PS: If you haven't done so already, I'd strongly encourage you to download a pdf copy of your user's manual. It's made my life a whole lot easier. You can use the search function in your pdf reader like Adobe Acrobat and search for specific things.
You can do a Google search for Canon T8i User Manual. One such site is here:
https://gdlp01.c-wss.com/gds/2/0300038762/01/EOS_850D_Advanced_User_Guide_EN.pdf
Another PS: When shooting videos, if you put your camera in one of the Creative Modes like Av (aperture priority), or Tv (shutter priority), your camera will default to the P (Program) mode. In the P mode, your camera sets your aperture and shutter speed. This is like your A (automatic mode), but with the added advantage of allowing you to adjust your ISO up or down to make your pictures or videos a little darker or brighter.
Steve Thomas
07-30-2024 07:43 PM
Thank you i will try that. I currently use ef-s 18-135mm usm lens. The videos are amazing with it. I also own the us ef 70 -300 II usm but that was an over kill. But im needing a wide angle lens. The band recently played on a huge stage and i couldnt zoom in enough to see them perfectly because the stage was the size that a play could be done on. I dont know if i can post the link to the youtube channel i uploaded the videos to but its under risingphoenixstudios on youtube band name is the horde of culture https://youtube.com/@risingphoenixstudios?si=gdCamnlDsIGYRNDZ
07-30-2024 07:46 PM
Thank you this helped alot. Ive downloaded the user manual.
07-30-2024 08:51 PM
Diagram,
I have the 18-135 lens too. It stays on my camera about 90% of the time.
I don't think a wide angle is going to help you with the larger venues. They have a wider angle of view, but with a much smaller focal length. I read that wide angle is generally considered to be any thing smaller than 35mm. You'll find most of these in the 14 - 40mm range.
One thing you could try is a 50mm f/1.8 prime. They only run about $120, but the optics are wonderful. The larger apertures of like f/2.8 would help in your low-light situations. You'll have to zoom with your feet though.
A 50mm prime, the "nifty fifty" belongs in every photographer's kit bag 😀
Steve Thomas
07-30-2024 09:33 PM
Diakara,
Since you take a lot of videos, I'll pass along a little trick I learned about. You can re-assign your shutter button to start and stop movie recording instead of using the little button on the back.
If you'd like to try this, put your camera in the video mode. Hit your Menu button, and scroll over to the wrench settings. It's the fourth one over, it's yellow and looks like a little wrench.
Scroll over to the 4th sub-tab and choose it. The second item in the list is the setting for re-assigning your shutter button.
I did that, and it makes things a whole lot more convenient; and because your video taking is now handled by your shutter, you can also control that video-taking process with a remote.
You can find the instructions here: https://support.usa.canon.com/kb/index?page=content&id=ART177050
Steve Thomas
07-31-2024 08:04 PM
Stevie,
Thank you i will definatly put that on my "to buy" list. Thank you for all your help.
07-31-2024 08:58 PM
Diakara,
Happy to help. If you ever have any questions, I'll help if I can.
Us T8i shooters have to stick together. We're too small of a group than to anything otherwise 😀😀
Steve Thomas
