12-13-2023
01:26 AM
08:23 AM
beginner here, im needing help!
a couple days ago I took family photos and before the session I changed my settings to custom (because my camera doesn't have kelvin setting) and I think it ruined my photos, when I apply my preset, the image turns green and I'm at a loss on what to do..
12-13-2023 07:05 AM
What camera do you have? And did you capture the images in RAW? If so, white balance isn't baked in to RAW images whereas in JPEG it is. So with RAW, you can easily set the color temperture and tint in post.
Also, when in doubt of what you've changed in your camera, reset its settings.
12-13-2023 08:10 AM
Thanks for joining the conversation, marie121!
To echo what Ricky asked and so that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-13-2023 12:05 PM - edited 12-13-2023 12:13 PM
"beginner here, im needing help!"
I concur it would be nice to know what camera/lens you are asking about. However, here is a tip that will fix most issues you have. You said, "... I changed my settings to custom ...". First that was probably a mistake. 9 times out of 10, P mode, AF lens and WB daylight with ISO 200 will get the shot like you were doing. If it is a low light situation up the ISO number. Sometimes the camera is smarter than you may think it is and it is usually a mistake to over think the shot.
12-13-2023 12:12 PM
" And did you capture the images in RAW? "
Of course, raw is best because WB can be adjusted to anywhere you prefer. Again though, you may be able to, at least to a degree, make the photos decent if they are jpeg. This requires you to d/l from Canon DPP4 Photo Editor it is free so there is no good reason to not get it. As is, there is no good reason not to use raw format instead of jpeg.
DPP4 can transfer your photos to your computer which you are probably already doing somehow.
12-13-2023 11:14 PM
canon rebel t7 with a 50mm 1.8 lens
12-13-2023 11:14 PM
i have a canon rebel t7 with a 50 mm 1.8 lens. i shot in RAW
12-14-2023 08:21 AM
What software do you use to convert your RAW files? Canon's DPP? Adobe Lightroom? You should be able to adjust both color temperature and tint.
With Adobe Lightroom (and probably other software), it has an eye-dropper tool which can get you in the ballpark if the image contains something neutral (gray/white).
12-14-2023 08:29 AM - edited 12-14-2023 08:31 AM
marie121,
Your better bet, I think, is to take your camera out of custom white balance and use one of the Presets.
Outside on a bright sunny day, use Daylight. This will help highlight the cooler blues and yellows.
On a cloudy day, use the Cloudy Preset. This will help bring out the warmer greens and reds.
Indoors, under regular household light bulbs, use the Tungsten Preset.
Steve Thomas
12-14-2023 09:35 AM
My suggestions since you have RAW files.
In the free to download Canon DPP software, load the RAW file and change the white balance to whatever Kelvin number you wish. Else, start by changing the white balance to daylight. If you had something white in the photo, the eye dropper tool might do what you want depending upon the lighting when the photo was made.
