06-22-2020
05:34 PM
12:35 PM
Hello,
I am new to the community and still a newbie with cameras and need some assistance.
I have an EOS Rebel T5i.
I wanted to make a short video. It has been a few months since I recorded a video with my t5i. Today, after recording and going into edit my footage on iMovie, it says that the format is not supported. I noticed my video saved as a MOV instead of the usual MP4.
I tried converting it to an MP4 and it was still not supported. (mp4, m4v, mpeg-4 are not supported)
I have tried putting the sd card into another camera where I can connect to the canon camera connect app, and the app is saying the same thing.
I'm not sure what happened to cause this change and would appreciate some help in fixing this for the future!
Update:
I can not reply to comments, without my comment being marked as spam. :L [We think we've fixed that!]
06-27-2020 10:43 AM
Try taking a copy of one of your .MOV files and change the file extension to .mp4 or maybe .mpg.
Stranger things have occasionally worked for me before.
06-27-2020 10:59 AM
06-27-2020 11:02 AM
06-27-2020 12:56 PM
Were your recording to a full-size SD card, or a Micro SD card with an adapter?
06-27-2020 01:10 PM
06-27-2020 03:04 PM
@BEpple238109 wrote:
I use a SanDisk 128GB Extreme PRO.
"Were your recording to a full-size SD card, or a Micro SD card with an adapter?"
06-27-2020 03:06 PM
Have you tried resetting your camera back to factory defaults?
Have you checked your camera menus to see what recording format is set to use? Use must be in movie mode to check this.
06-27-2020 03:18 PM
06-27-2020 03:22 PM
My camera was originally on 1920x1080 24fps 29:59.
I did reset everything prior to posting in the community and it did not fix the issue.
Is your camera set for saving video as MP4 or MOV file format?
Have you formatted your SD cards prior to first use. This is highly recommended for all new cards. I think it is a best practice to reformat a memory card prior to video shooting session, not unless you doing short videos of the kids running in the backyard.
06-27-2020 03:29 PM
