EOS Rebel T3i - Does anyone have any tips on how I can get better with sports photography
Pibc1104
I’m currently the team photographer for my schools football team. We have both day and night games and I noticed that it’s a lot harder to get good pictures at night. I generally shoot with a  ES-F 55-250mm f/4-5.6 IS on a canon rebel T3I. I generally also use auto focus.
10 REPLIES 10
Waddizzle
Can you post sample images of your work that include the shooting info and EXIF data.  Are you familiar with the “Exposure Triangle” and “Depth of Field”?
Shooting at night is completely different scenario compared to shooting in daylight.  I’ll discuss shooting in daylight for now.  Once you understand daylight shooting, the additional challenges of shooting at night should be easier to understand.
The “secret” to success action photography is to use a FAST enough shutter speed to freeze the motion of your subjects.  For football, you want to be at least 1/800 or higher, preferably 1/1600 or higher.
However, a faster shutter means less time for light to reach the image sensor, which means you will need raise your ISO.  Raising your ISO will usually mean increasing levels of noise in the captured images.
One way to avoid raising ISO too high is use wide aperture lenses.  The aperture range in your kit lens is adequate for most daytime shooting.  Bear in mind that the higher the focal length, then the sampler the aperture.  The smaller the aperture is, the smaller the amount of light reaching the image sensor, which means having to raise the ISO.
Another impediment is the focusing speed of the 55-250mm lens.  It is not very fast, but it is certainly fast enough for the continuous shooting frame rate of the T3i.  This could be where you are having an issue.  The camera does not wait for a focus lock in AI Servo AF mode before it fires the shutter.
One Shot AF mode does wait for a focus lock before the camera fires the shutter.  But, this will often mean a small lag between when you want to take the shot and when the shutter actually fires.  The usual result of this scenario is you miss the moment because it has come and gone before the shutter fired.
So, you have to make trade-offs when it comes to performance.  You have to rob Peter to pay Paul, as the saying goes.  Post some images with shooting and EXIF data, and let’s work from there.
Waddizzle
Oh, yeah.  What type of school are you working for?  High school?  College?
What is your current and?or favorite shooting locations for football?
So this was one of the photos that wasn’t like great but not horrible, I generally keep my settings to fluorescent light and intense because of the lights on the field, then I just use auto so I’m not sure about the other stuff?
Highschool, I’m kinda limited with areas for it but I get to be on the sideline. Generally I’ll line up at the line of scrimmage and just watch through the camera for the moments.
Successfully capturing photos at night almost requires that you understand “the other stuff” that I mentioned.  “Exposure Triangle” and ?Depth of Field”. Check out this series of videos released by Canon USA a few years ago.
EOS 101 Series
There are 13 videos in the series.  Each is about 5 minutes long.  You will want to watch this on a screen larger than a smart phone and with your camera on tripod in front of you.
Great.  You are on the field, not shooting from the stands or a press box.
The line of scrimmage works for shots of the line of scrimmage.  The best location on the field really depends on where on the field the teams are located, and what type of play is most likely to called next.
Screenshot 2022-09-02 191426.jpgYour shutter speed was 1/15 sec. Even in broad daylight you wouldn't get a sharp image at that shutter speed just due to camera shake from your body motion. Rule of thumb is minimum shutter speed to avoid motion blur is 1/focal length. Your lens was at 146mm focal length. You would need a minimum shutter speed of 1/150-1/200 sec. At that is not accounting for subject motion.
Amateur night sports is very demanding of equipment because lighting is generally not the best.
It is going to be very difficult with your equipment.
Tintype_18
This has been enlightening. Watching baseball on TV, I noticed that a lot of photographers use a monopod. I do notice also that they are using very large lenses. I'm guessing the monopod is to help steady the camera and eliminate camera shake.
John
