11-03-2023 01:15 PM
Hello, I recently purchased a Canon R8 to use with my kit of Rokinon cinema EF lenses, which are completely manual through the original Canon EF-R adapter. When using the HDMI output, everything works perfectly, but I can't take photos or shoot videos directly on the camera. When I press the shutter button, the MF symbol flashes on the screen, and neither the photo nor the video is captured (each in their respective mode). I've tried changing all the settings in the AF menu to manual, but I believe I'm not doing something correctly, and I need your help to use the camera properly. I look forward to your response. Thank you very much for now.
11-03-2023 01:27 PM - edited 11-03-2023 01:30 PM
Do you have the "release shutter without lens attached" option enabled?
C.Fn4
Canon : Product Manual : EOS R8 : Custom Function Setting Items (start.canon)
C.Fn4
11-03-2023 01:58 PM
I didn't find that option in the camera menu, only the "release shutter without a card attached" option, which is currently enabled, but I also tested it with it disabled.
11-03-2023 02:07 PM
Now I found it. Thank you very much, you saved the day. God bless you.
11-03-2023 06:21 PM
And to you 🙏
