05-10-2026 05:39 PM
Hi, I have a Canon R7 and R5 paired with Rf100-500mm and Rf70-200mm usmz, and I am struggling at getting good captures. I shoot wildlife and used to shoot with the Canon 6d mkii and Tamron 150-600mm g2, and produced very good (not professional grade but for my level, very good without editing) and now 90% of my shots are grainy, noisy. I know it's a vague question but any feedback on what could be happening, settings, etc.? I get it if I were at a high IS, low light, or blurred photos however it's grainy and not crisp on nearly everything I shoot. I was trying to upload some pictures for examples but my files are too big. Any feedback would be greatly appreciated. If I need to upload some samples, I will try and resize some samples. Thank you in advance!
05-11-2026 07:57 AM
Ceddy,
What I was thinking is that cameras need contrast to accurately find a focus point and there is not much contrast between the owl and the branches he is sitting on in the example that has been provided.
You might be better off choosing a single point AF with the point zeroed in right on his eyes.
To me, the shot of the owl is way over exposed, probably as a result of using an ISO of 3200 pointed right at the sky.
In my inexperienced opinion, I believe that you would be better off with a slower shutter speed and a lower ISO.
Steve Thomas
05-11-2026 06:05 PM - edited 05-11-2026 06:25 PM
@Ceddy wrote to FloridaDrafter: "Ok, I am very amateur in the photography world- so all of that is totally greek to me, so I will do what I can. Can you see the picture at all that I uploaded? I was able to re-size the photo."
Yes, we can see your image but a Raw file would be more helpful. There are sites that allow you to upload and share Raw files. The reason to share your Raw is so that we can get a better idea of what your settings were and to see it before editing and resizing. Turning your image into a JPG file to edit or resize can take a toll on quality and, in some cases, introduce noise or grain.
@Ceddy wrote to FloridaDrafter: "Thank you for the encouraging words, however, maybe I will need to add a different example. I am thinking maybe Shadowsports addressed my concern also by stating that I am set at 1/1600th on a static object. Should I not be doing that?"
Yes, different examples would help, preferably several shots with differing lighting and/or environmental conditions that you find troubling.
As for shutter speed being a problem, I guess it's possible, but IMO, for perched it is more unnecessary than a problem. I typically stay between 1/600th - 1/1000th, depending on the lighting and how much the bird is moving, like preening or looking around while foraging. It may cause a problem when shooting in the "creative" mode, Tv when letting ISO float (Auto ISO) because shutter speed will have a direct effect on the other 2 legs of the exposure triangle, but I noticed that you are shooting Manual Exposure mode (M), which I don't recommend as a beginner. I do up my shutter when shooting Birds In Flight (BIF), but even that depends on what effect I am after, for example, sometimes I don't want the bird to look "frozen" and prefer a bit of motion blur on the wing tips. It helps convey motion even though it's a flying bird ("The mind is a terrible thing", LOL!) Since it's wings are moving way faster than the birds body, the body will be sharp even if the wings blur.
@Ceddywrote to FloridaDrafter: "Should I not be using those settings together? Is OP mean operator? I am so NEW at this!!!! Thanks for your input and time!"
You are welcome!
Many of us use those combinations, just not all the time. Take note of the custom functions (C1, C2, and C3) on your functions dial. As the name implies, you can configure your cameras "still" shooting parameters and store up to 3 of them there. I store the settings that I use for H1 continuous, tracking, servo, eye detect, etc. in C1 and single shooting with the fine focus point, for peeking through branches an leaves, as my main setup (no custom function).
OP stands for "Original Post" or the thread starter 🙂
Another tip that I would like to pass along is a setting that may help you with exposure. It's called "Exposure simulation", except in the R7 it's referred to as "Display simulation". When enabled it will give you a very close approximation of your exposure. A good explanation is in your users manual on page 308. Meanwhile, press the Menu button and navigate to the Shooting 9 tab (Red camera, tab 9) and select "Display simulation", then select "Exposure"
Sorry if I have been a little too detailed, I do understand that you are a beginner. I just hope I haven't overwhelmed you with info... Feel free to ask away as there are many many fine folks on this forum!
Newton
05-12-2026 07:30 PM
Oh thank you so much for all of the feedback and advice. I learned about being in Manual mode early in my DSLR beginnings, and it was advised so that I could learn to adjust the "triangle", which I am learning and of course, missing many shots but also producing pretty good shots. I have been complimented on my JPEG captures, so I guess I get so confused when I read about how JPEG doesn't produce as good as captures. I will play around and try and post some examples. I haven't learned Lightroom so that's another tool that I have dabbled in and found that my pictures seem too crappy to do anything with in LR. I don't know...I'm going to get some things together and be more prepared when asking for help in this forum. These questions began to boggle my mind more. Hahaha~again, thanks!
05-12-2026 07:32 PM
That's a strong perspective-I am learning more and more. I shot a snowy owl (yes, in May) the other day but it was so windy and the grass kept moving in front of it, therefore not allowing me to get a good sharp focus. I am learning my problem may be, too, when to use a tripod. So many variables! Thank you for your response!
05-12-2026 07:33 PM
Ok, I appreciate your feedback and suggestions. I will adjust my settings accordingly!!! Thank you!
05-12-2026 07:39 PM
Actually I sent the wrong example, and that was the R7 with a RF100-500mm. However, the other set up is with the R5 with RF70-200mm f2.8 usmz, and that didn't produce the shots that I expected either. However, with the feedback that I have received, the suggestions would apply to either set up and results. I have a lot to figure out, I feel like I am going back to the drawing board, which is deflating since I've shot Manual mode for several years with my Canon 6d mkii and Tamron 150-600mm g2, and produced many (not professional grade) but complimentary shots. So I think I need to keep practicing but it definitely makes me nervous about being in a "once in a lifetime moment" and lose the shots. Thank you!
05-12-2026 09:15 PM
Ceddy,
For several years, I too have been shooting in Manual. Lately, I have been using Aperture Priority. I decide if I want a deep depth of field, or a shallow one, and set my aperture accordingly, and let the camera set the shutter speed to give you a good exposure. I find it much less stressful, as I was constantly tinkering with the shutter speed. Sometimes, even the act of breathing was enough to throw the exposure off, and with Aperture Priority, the camera can adjust a whole lot faster than I can.
I find I am enjoying the act of taking pictures more. I'm using Auto ISO, but I keep an eye on ISO, and if it starts getting into the ridiculous range, I can widen my aperture to let in more light, or use exposure compensation to darken or brighten the image slightly.
Steve Thomas
05-12-2026 09:52 PM - edited 05-12-2026 10:08 PM
I didn't mean to imply that JPeG isn't a capable format for some purposes, only that for us to examine and maybe see whats going on, RAW is the preferred format for troubleshooting.
While you're messing with LR, download Canon Digital Photo Professional 4 (DPP 4) from the Canon Support page for your camera. It's not as robust as LR, but very capable, much simpler to use, and has built-in profiles for your Canon cameras and various Canon lens optimizations.
I am assuming you shoot Raw?
Newton
05-14-2026 10:50 AM
Oh I am sorry, I didn't consider it that way at all. I am so new to how to phrase my questions/comments to get the most out of my feedback. I will definitely be absorbing all of the feedback that I've received, learn to upload some better examples and hopefully get into producing better photos again. Clearly it's settings! Thank you again (Everyone!)
05-14-2026 10:52 AM
Thank you for that tip also as someone had given that advice to me once before and I am glad that I listened on this occasion where a Great Grey Owl was in the woods and came out into the snow and I was able to achieve a wonderful capture having it on AV. I will definitely keep that in mind more often. Thank you again!!!
