11-28-2024
05:15 AM
09:00 AM
I am using a R7. How do I shoot in Jpeg? The out files are in RAW and HEIF only. I am not able to open .hif on my PC. The DPP software does not display the HEIF flies either. I have checked my image setting and updated the firmware to the latest version. Thanks
11-28-2024 12:54 PM
You have selected HDR shooting HDR PQ. When this is used the images created can only be saved as .HIF and or RAW images. If you turn this setting off, then your camera will create .JPG and or RAW images.
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0100.html
You can use the playback menu on your camera to convert any .HIF images to JPG, go to the blue play back menu, search for HEIF -> JPG conversion.
https://cam.start.canon/en/C005/manual/html/UG-06_Playback_0250.html
11-28-2024 07:25 AM
Is JPEG setting not available? It should be shown on page 1 of the camera's main menu-
https://cam.start.canon/en/C005/manual/html/UG-04_Shooting-1_0030.html
11-28-2024 07:50 AM - edited 11-28-2024 07:50 AM
Aren't Heif used for HDR images only?
11-28-2024 09:25 AM
Hi. The main menu stated "Jpeg/HEIF". The resulting files saved to my card are only .hif, which I have problems viewing/editing. Is there a setting to output .jpg files from the camera as well?
11-28-2024 12:54 PM
11-28-2024 07:24 PM
It works! Thank you so much.
Gary
