EOS R7 Single Point AF
oliveJar
Hello, I am a bird photographer. I just purchased an EOS R7 and like the subject tracking and eye detection AF. In my old EOS 80D I had the option to pick a single point and the camera would focus on that point only. I sometimes need this capability while photographing a single bird out of a flock. Is this sort of capability available on the R7? I cannot seem to find it.
oliveJar
Thank you everyone for the replies.
I got the camera set up the way i want.  I was able to get it to focus on a single bird or use eye tracking as desired.
10 REPLIES 10
jrhoffman75
You need to turn tracking off.
I forgot to mention that I have have tracking and eye detect turned off by default and have set up buttons to enable/disable them. This doesn't seem to help.
Waddizzle
It should work almost identically as the DSLR.
Just remember, once you select a single AF point it does not change or move around on its own.
Not sure I understand. Are you saying you can't select Single Point AF?
I have Single Point AF selected with tracking off but the camera still moves to other subjects.
oliveJar
I will try some things today or tomorrow to verify the settings and operation.
You could give Canon a call at 1-800-OK-CANON
oliveJar
firstmirrorless
I'm having the same issue. Can you tell me what you did to make the focus point stay in one place?
