EOS R7 LCD Fault - lines appear on screen
twj42
HI, I'm having a curious issue with my R7 LCD screen. Two horizontal grey lines appear on the screen, approx. 1mm in size, one at the top, the other the bottom, about 2mm from the edge. They appear no matter the what configuration the display "Info" is in, including the thumbnail on the histogram display. They do not appear in the actual images, through the viewfinder, or if you touch the screen to (say) flick through captured images. Apart from this, the camera appears to work OK.
The camera in 2yrs 2mths old, so just out of warranty 😞 FW 1.7.1.
Anyone seen this, or have any ideas?
twj42
This is a weird one - it appears to be related to / caused by, the memory card. It goes away if I change to a new memory card, and when I reformat the original memory card. If the source images showed the same characteristics, I could understand it, but since it is just when it is displayed on the LCD leaves me baffled.  Anyway, mark this one solved (for now 🙂 )
10 REPLIES 10
jivecem383
Hello,
Since the lines don’t appear in the viewfinder (EVF) or the final image files, we can rule out sensor damage. The fact that they disappear during certain touch interactions or playback transitions suggests a voltage or synchronization glitch within the LCD panel itself rather than a permanent "dead pixel" row. While you could try a full camera reset or a firmware re-install, this is typically a physical degradation of the display component that often occurs just as the hardware ages
Waddizzle
Do not attempt to reinstall your firmware.  Firmware updates do not repair electronic malfunctions.  Besides, if you attempt to reinstall firmware, the camera will gong you and tell you that the firmware is already installed.
If the display functions normally when you view the menu system, then there’s nothing wrong with the display.  I advise doing a full reset of the camera.
Just tried a full reset, lost all my settings, which will be a pain, but the fault is still there. Given how much of the camera works, if it is a hardware fault must be very niche, all I can think of is the memory that supports the LCD display while it is those modes. Have reported it directly to Canon, we'll see what they say.
Do you see these lines when you open the menu system?
Could you take a picture of what the lines look like.
Here you are. Lines only appear when the LCD is in this mode. As you can see, if I touch the screen to move to next image, the lines disappear.20260107_092506.jpg20260107_092517.jpg20260107_092631.jpg20260107_092708.jpg
Waddizzle
“ If the display functions normally when you view the menu system, then there’s nothing wrong with the display.  I advise doing a full reset of the camera. “
As mentioned, I've already done this, and it has had no effect.
twj42
You should mark it as solved.
Friends and Family
