12-08-2023
09:08 AM
09:10 AM
I'm having difficulty viewing the icons on the flip out display clearly without the aid of glasses on my R7.
Is it possible to increase the size of the icons?
So far I haven't been able to find a way to do it.
Thanks,
Denny
12-08-2023 01:18 PM
Hi Denny,
Thanks for your feedback. Thats all the functionality which is offered currently. The size of the icons on the LCD and EVF cannot be adjusted. 😃
12-08-2023 10:23 AM - edited 12-08-2023 10:32 AM
Give this a try. Wrench Menu, Tab 4.
Canon : Product Manual : EOS R7 : UI Magnification (start.canon)
I upgraded the FW on my R5 C yesterday. The Cinema Menus are even smaller than the Photo side. (Had to grab my glasses too) 👓
Just to give you an idea
12-08-2023 10:59 AM
Rick,
Thanks for your response. I tried the UI Magnification per the link you sent above. This seems to only enlarge the text in the menus as opposed to the size of the icons when you're using the display to compose an image.
Maybe that's as far as the R7 goes in allowing you to customize the display.
Denny
12-08-2023 12:16 PM - edited 12-08-2023 12:19 PM
Wow! That's a nice feature. I'm surprised to "see" (pun intended) that it's even available. And with the touch screen you can easily turn it on and off. Wish I could do that on my TV. 32" screen and 6 or 8 feet away you can barely read some of the displays or menus. 🤓
12-08-2023 01:18 PM
Hi Denny,
