10-25-2022 12:03 AM
I bought R7 recently but it won't allow me to select either "Continuous High" or "Continuous High+". These two options are grayed out. The only option is "low speed continuous". I found some previous tread on similar issues but the "solution" provided there does not apply to my case, as Dual Pixel RAW is disable on my R7 already. Did I miss some settings?
10-25-2022 12:14 AM - edited 10-25-2022 12:15 AM
Hi and welcome to the forum:
I'm not sure to what thread you are referring but you cannot use these features when you have auto level to enable, as per this on P293 of the Advanced User Guide
09-23-2025 07:01 PM
Press the menu button and find the auto leveling setting. Set it to disable.
10-25-2022 01:45 AM
Thanks, Trevor, for your advice! I changed "AUTO LEVEL" from "enable" to disable" and now both "Continuous High" and "Continuous High+" are available in my R7. By the way, I did check the manual and the support site but couldn't find a solution to my issue. Thanks again for your help!
10-25-2022 01:49 AM
Glad to be of assistance. If you can mark the post that sorted this as a resolution, you won't keep getting posts from folks still trying to solve it.
FWIW, I suggest downloading the PDF version of the Advanced User Guide, as one can do a search for key words in the body of the text, which is how I found what you were looking for.
Enjoy your new camera!
10-25-2022 01:55 AM
Thanks, Trevor, for your advice. I've downloaded a copy of Advanced User Guide and will search by keywords in future. Best regards!
09-23-2025 05:50 PM
Hi Trevor
i have the same problem but I do not understand you fix?
please could you describe it more
many thanks Tom
09-23-2025 07:01 PM
09-24-2025 03:00 AM
Thank you, you have solved it!!!
I knew it was going to be simple.
many thanks Tom
