07-01-2023
12:21 PM
09:00 AM
James_C
I've been using my R6 for a while and I usually write RAW to both SD cards. Recently, I decided to try writing Raw to Card 1 and JPG to Card 2. R6 strangely malfunctioned and 31 photographs in Card 1 were saved as JPG instead of Raw. All photographs in Card 2 were saved as JPG (as instructed). Anyone encountered similar ?
31 photos were saved as JPG instead of RAW
My camera settings
My camera settings
My camera settings
My camera firmware
07-01-2023 01:30 PM - edited 07-01-2023 01:31 PM
Just a guess, but did you by chance remove card 1 from the camera? (and close the door). If you remove the card and close the media slot door, the settings for storage will change. I'll bet this is what might have happened. The trick when doing this is don't close the media slot door 😀
07-02-2023 06:42 AM
Greetings Shadowsports ,
Unfortunately no. The cards were inserted before and left untouched until after the shoot. Its a perplexing issue .. .
07-02-2023 09:26 AM
What were you photographing? Were you using any of the special features that are only captured in JPG format?
07-02-2023 09:48 AM
Double-checking that you've intended to capture C RAW (Compact RAW) instead of RAW.
What types of SD cards are you using? Full-sized or micro with an apapter? The latter can cause issues.
I would recommend resetting the camera to factory settings; perhaps some setting got changed or corrupted.
07-02-2023 11:18 AM
"I would recommend resetting the camera to factory settings;..."
Always when things don't go according to plan and there doesn't seem to be a good explanation. Reset it to default settings and start over.
07-02-2023 11:22 AM
Hi~ Thanks for commenting. I was photographing an event and I was mostly in Manual mode. Unfrotunately, I'm not aware of any special features for JPG format so I guess no ? haha...
07-02-2023 11:25 AM
Hi rs-eos~
07-02-2023 11:27 AM
Hahah the golden rule.
I was hoping to maybe get some insights and see if anyone else had a similar problem before reformatting since it was such strange issue. But yes, ultimately it might be the only solution haha.
05-11-2026 11:00 AM
I just experienced the same issue. Card 1 set to RAW, Card 2 to Medium JPEG. Out of 570 files, 30 was captured as compressed JPEG (2432x1824). And 72dpi.
