06-17-2023
11:36 AM
11:36 AM
I just got my refurbished R6 in the mail yesterday and while taking some test shots of low light settings I noticed a lot of black banding across my photos. These photos were taken with multiple light sources, and NO flash.
The banding is consistent with the camera orientation. So when i hold my camera in landscape the black banding is horizontal, when I turn it to portrait the banding is vertical. Does this look like a shutter issue I should RMA for?
R6 body (canon online store)
Canon EF>RF adapter with control ring
EF 85mm L ii lens
06-17-2023 11:53 AM - edited 06-18-2023 10:55 AM
"... while taking some test shots of low light settings ..."
And, while shooting in daylight is it OK?
06-17-2023 12:13 PM
What type of lighting? Perhaps it is a flicker issue?
06-17-2023 01:57 PM - edited 06-17-2023 02:29 PM
Need to research. I thought I read something about this somewhere. Might be mistaken though.
Can happen in video... still looking for confirmation in stills:
Canon R6 Sensor Banding? - Canon Community
***Ernie's suggestion of a settings reset is where I would start.
Your issue does not look like banding. Flicker as John mentions seems more likely. Your issues looks like downright shadows, so I would test in daylight. If you are using electronic shutter, change to mechanical.
Other test scenarios:
Shoot in RAW, Daylight. Set ISO to 100 and test. Do you see banding or shadows?
Now change ISO to 200 and perform the same test. Is banding/shadow still present?
Don't worry if there is an issue. Canon will make it right. I've bought plenty of refurb gear and all has been well.
06-18-2023 05:50 PM - edited 06-18-2023 05:52 PM
Try turning on Anti-Flicker shooting in the menu. It does look like flicker caused by fluorescent or LED lighting. Anti-Flicker setting should help if this is the issue.
