05-12-2024
07:18 PM
08:53 AM
R6 Mark II- Weird stuff going on
First off, I am just a sports mom who loves to capture my kids and their teammates.
The first 2 attached photos are examples of what happens towards the later part part of games. Not always, but always in the most opportune moment! The first example was taken at night. Other shots come out fine and then it is as if gremlins take over! The 3rd is just an example of the lighting on the 2nd- it was taken within minutes of the green.
I am using EF 70-200mm f/2.8L IS II with R adapter.
Any thoughts to what's going on?
Thank you so much!
05-12-2024 09:04 PM - edited 05-12-2024 09:05 PM
Is the camera always producing this problem. It could easily be a bad SD Card causing this problem. Check to see if this also happens when the camera is in live view or through the EVF.
05-13-2024 07:25 AM - edited 05-13-2024 07:26 AM
Ali_H,
I cannot say I know what's going on, but just to throw out a couple of ideas:
1) It looks for all the world like you have a neutral density filter on the front of your lens. Do you have an ND filter mounted?
2) Have you tried changing your White Balance when this starts happening?
3) You say this starts happening towards the end of the game. It's possible that this could be a sign of overheating. When this starts happening, does your camera feel warm? Try turning it off and let it cool down for a while, or turn it off in the middle of the game for a while so you are not shooting for hours at a time in one long continuous stretch.
4) if you shoot in RAW, you can go in later and remove the green tint with your editing software.
Those are just a few ideas, but like I said, they're just guesses.
Steve Thomas
07-11-2024 07:23 PM
Hello, how are you? I have a Mark 1DX ii and im having the exact same problem. Have you figured it out?
Thanks
07-11-2024 08:16 PM
I am not an expert in fluorescent lighting, but could it have something to do with the flickering?
Steve Thomas
07-11-2024 08:19 PM
No, it crossed my mind too, but I did some tests in several environments and still the same.
Also change the white balance, and same thing.
Thanks for your reply. I truly appreciate it
07-31-2024 07:01 PM - edited 07-31-2024 07:03 PM
Did you get this issue resolved? Honestly, looks like the camera needs to be sent back to Canon. No reason for it to be showing that kind of noise along the edges like that (I wouldn't think it's over heating, lets say three photos are taken, and the third one onward look like that, that's pretty suspicious) or green for that matter. It sounds like it's more of an electrical/sensor issue. I've seen something similar when a friend attempted to clean their sensor, tons of noise and discoloration in photos.
07-31-2024 10:54 PM - edited 08-01-2024 01:38 AM
Looking at the degree of green bias, and major peripheral noise, I suspect a sensor error, possibly in the processor stage where the colours separated in the Bayer array are integrated into a colour image.
I would recommend contacting Canon support and have a chat with them.
