- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
11-14-2023 08:11 AM - edited 11-14-2023 08:14 AM
How can I recover my photos after accidentally formatting the memory stick of my Canon EOS R6 Mark II
Hello! Faced with an unpleasant event . Accidentally formatted memory on the Canon EOS R6 Mark II camera.
And all my pictures are gone. After a little Google research, I realized that to recover your photos need special software. I even tried a few but did not achieve the desired result...
Does anyone know how to help me?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2023 07:39 AM
You can try Hetman Partition Recovery. It's a paid program, but you can scan your USB drive with the free version of the software. It will show you the files it can find for recovery. If the program finds your lost files (photos), then only then you buy the program and transfer the lost files.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 08:27 AM
They are gone if you have performed a low level format.
If you did a normal format you can use software like Recuva/Photorec.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 08:34 AM
Did you format both cards (assuming you equipped the camera with two cards and set it up to save images to both)?
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 09:28 AM
I tried to restore with these 2 free programs, but nothing found. Is there any good paid programme?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 09:41 AM
If these were once-in-a-lifetime photos, and you didn't perform a low-level format as Peter mentioned earlier, you can also seek out data recovery companies. It can end up being very expensive though.
Ricky
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 10:06 AM - edited 11-14-2023 10:43 AM
Did you with Photorec try the whole disc and in the next window choose Other? Also take a look under file option that your raw format, CR3, is checked.
Have you tried Disk Drill?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2023 11:32 AM
A low-level format writes directly to the sectors. Every single bit is overwritten with zeroes and the SD is returned to its factory state. Consequently, any chance of low-level format data recovery vanishes once the low-level format is complete. There is no “true” low-level” data recovery app that can recover data from a completely low-level formatted SD. Sorry. 😣
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2023 07:30 AM
There was only one memorial card.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2023 07:31 AM
Yeah, I tried that. It doesn't find anything.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2023 07:39 AM
