EOS R6 Mark II freezing frequently
Blackscarlet
Enthusiast
I am a club and event photographer who works 6 nights a week. I have a canon R6 and I kept having freezing issues, where the camara becomes none responsive and i have to take the battery out before it works again. This occurs every night. Depending on the club, up to 8 times an event within a 1hr time frame. I sent the camera to be repaired under warranty and while it was gone I bought the 6d mk ii. Withing the first 25 mins of using it , it began to freeze up as well. unlike the r6 which had an error code , this just has a dark grey screen and yet again i have to remove battery to reset. I use all canon original gear. Is anyone else having same problem?
If this persists I will have to return the camera for a refund.
Update. i also got my 6d back and withing first day it started freezing again but this time not showing an error code.
70 REPLIES 70
Waddizzle
Make sure that you have disabled Bluetooth and Wi-Fi.  The GPS could be the cause issues, too, if it loses the satellite signal.
deebatman316
Hi Blackscarlet are you using adapted EF lenses on your R6 Mark II via the EF-RF adapter. Also are you using those same lenses on your 6D Mark II. A common link between the 2 cameras could be a faulty lens communication.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM (Retired 8/2007-11/8/2022), EF 50 F/1.8 STM & EF 70-200mm F/2.8L IS III USM
EOS 40D (Retired 8/2007-5/26/2022) & 5D Mark IV
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
sorry this doesn't work
Hi
That's what i thought till it started doing the same with my rf 24-105mm as well
Do you any other lenses that you can test out on your R6 Mark II whether native or adapted EF glass. Do you have other EF lenses that you could test out on your 6D Mark II.
-Demetrius
-Demetrius
Hi i use 6 lens ef 24-70 f2.8L mk2, sigma 24mm 1.4, fisheye ef 8-14mm f4L, 50mm 1.8, ef 16-35 f4L, ef 85mm 1.4. This issue has happened with all these lens. i have just bought a new adaptor today will try it out and see what the results are like. Also i tried using only back screen last night. It still froze on me. Evf also takes about 3 seconds b4 it can adjust to the dark, way slower than the R6.
Are those same EF Mount lenses causing problems on your 6D Mark II also. Or only some of the above mentioned lenses only.
-Demetrius
-Demetrius
Update didn't use new adaptor because I wanted to lock on and  making sure I tried as many of the lens as possible. same problem again occurs with the freezing up. I have slightly managed to narrow it down. Low light ie nearly pitch black areas in the club almost always makes the camera freeze up , when I try to focus . occasionally it freezes in mother areas, , this is with both Ef and RF lens. I will try new adaptor tomorrow , I am in the same club which I have the most problems in. I had a job an our before and the camera only froze once. the club which was darker it's froze about 9 times , generally in the same area of the club. it's so bad that when I look in the to evf to frame and focus, it's just pitch black. even though before raising it to my eye level I can see the camera working fine.
Wow.  Such a wide spectrum of hardware with the same behavior.
Me - T6s  Sandisk cards.  Canon . Sigma APS-C lenses.  Camera never froze. Owned for years.  (sold it)
6D2, only one freeze in its entire lifetime.  (still own it)  Canon and Sigma EF lenses.  I think it was the card.  I may not have formatted it in camera before use.  Usually shoot about 300 shots. + some video.  GPS always on, mode 2 (on when camera is on, doesn't check for signal when power is off).  Always use Sandisk Cards, Extreme Pro UHS-I.  Rock solid performance.
Now R5 C.  Arrived with FW 1.0.0.1,  Upgraded to 1.0.1.1.  Started using with Canon EF to RF adapter, Sigma 24~70 f2.8 Art.  Worked perfect in photo mode.  Quick, smooth and sharp.  In Cinema mode, AF was sluggish.  Wasn't hunting, it was just slow.  Was talking with another user who has the Tamron 24~70 G2 and that lens didn't work at all in Cinema mode on his R5 C, but was perfect on his C300 mkII.
A week later I had a RF 24~70.  Went out the following day.  I was so blown away with the performance I came home and completed the trinity.  Took a trip.  Carried the RF 24~70 and adapted EF 70~300.  It was great.  Bonded with the camera 12 days straight.  Didn't go crazy.  I took about 1,000 photos and a few videos.  Angelbird CF Type B and ProGrade v90 UHS-II.  No card reader on the trip.  I copied photos off the camera each night to a laptop.  I shot about 300 images on the adapted Canon lens.  No issues.
I believe that something in your settings, or hardware is causing the freezing.  I've had one freeze on one body, last 3 body's and you are freezing on all of your body's.  This is suspect.  Hope the new adapter helps.  Also try formatting your cards in camera.  If you are swapping frequently between bodies without formatting funny stuff can happen.
