01-23-2026
02:42 PM
08:07 AM
Has anyone else had this issue with the R6 MK II?
Recently purchased a RF 35mm 1.8 STM.
I am having a problem when used with my R6 MK II.
When using the Av mode - One Shot...regardless of one Spot AF, 1 Point AF or Expanded it does not lock onto the selection I choose on the joystick in the back for the focusing point.
I am using BAF.
Also using Subject Detect to Auto - Eye Detectin Auto
Does not matter the AF setting.
If I change the Subject Detect or the Eye Detection settings it will not change the situation.
I am also getting the same thing on my RF 100-500mm L
It also occurs in bring window lighting so not a low light focus hunt.
Canon wants me to send it in and of course it is just out of warranty since November.
https://u.pcloud.link/publink/show?code=XZ26pK5Z2Ltr1BTlcIYgb2sDVXcuK7DoDuDy
01-24-2026 02:04 PM
I wanted to reach out and thank you for all of your help the last few days.
Not sure what setting was causing the issue, but did some camera resets find a solution.
The basic reset did not work unfortunately, but did reset all other options in the "Other Settings" selection, EXCEPT "Root Certificate" and the "Custom shooting mode(C1-C-3).
This resolved the issue without losing my custom "C1-C3) settings which was awesome,
Appreciate you a lot and the time to assist/respond to my details a lot ! ! ! ! !
01-23-2026 03:25 PM
Thanks for the video. I cannot get mine to perform like yours. Is "Touch & drag AF settings" on Menu 4 in RF "ON"? It might be helpful to the group if you could just send us all of your AF settings to see if we can recreate your issue.
01-23-2026 03:38 PM
Thank you very much - Touch and drag is off.
https://u.pcloud.link/publink/show?code=VZKBRK5Zf5M8oChNRQBPgTq6rMczkYW06RA7
01-24-2026 01:23 AM
“ Thank you very much - Touch and drag is off. “
The simplest way to disable the touchscreen is to close it.
There are a couple of ways to disable the touchscreen. But each setting seems to only disable the touchscreen when the camera is in a specific mode. For example, the Touch AF Disable setting seems to be intended to only disable the touchscreen when the metering and AF systems are activated.
There is a setting in the Orange menu that disables the touchscreen in any camera mode. That includes during image capture, image playback and editing, browsing the menu system, etc. It’s more effective than the LOCK setting.
01-24-2026 08:23 AM - edited 01-24-2026 08:24 AM
I don't have your lens, but used both the RF 35mm f/2.8 and RF 50mm f/1.8 and could not duplicate your results.
From your video it appears what what might be happening is that your camera is unable to get a focus on the dark and distant area that you have selected using Expanded Area Autofocus and thus it is seeking focal points to get focus.
I would suggest trying changing the following settings to see if you still have the problem, perhaps one at a time then testing to see if there is a single "smoking gun" causing your problem - change AF area to "Spot-AF" (I know you said you'd already tried this, but mentioning it still as the mode you are in allows the camera to collect more AF points and thinking we should eliminate that), change Sensitivity - AF pt select to "0", change Orientation Linked AF point to "Same for Both Horiz/Vert", change Lens Drive When AF Impossible to "Off".
You may have tried all of this, but these settings, I hope, will cause the camera to only focus on the single point that you've selected and not others. It may then fail to focus and not take a photo, but that's actually an expected outcome. Maybe some others here will have more ideas to share if these don't work for you.
If they do then you can adjust accordingly. I personally only use Limit AF Areas to only use 1-Point and Whole Area AF and have a the AF Selection back button to switch between them.
Let us know what you find out.
01-24-2026 09:14 AM
This is not from touch and drag
i can handhold not even near the screen when this occurs.
01-24-2026 10:54 AM
Touch and drag was just a curiosity. I wasn't suggesting that was the culprit.
01-24-2026 02:04 PM
01-24-2026 02:36 PM
That is great news! Sometimes better to be lucky than good!
01-24-2026 04:33 PM
For sure and thank you so very much for trying to help - Means a lot !
