EOS R6 Mark II Glitches and errors after updating firmware to v1.4
Scarabesh
Hello,
   I have been using the R6 II for a year and half and have had no issues with it until Firmware 1.3 and 1.4. 1.4 was supposed to fix some of the issues with 1.3 but now I am getting some weird glitches and errors. I believe the one I got today was error 67, sensor error. The EVF was black with all the icons visible, the controls were dead and then the Error popped onto the screen. I pulled the batteries, replaced them and the camera worked fine. yesterday, while using my Sigma 60-600 S I was having issues with the EVF freezing, going blank but it never posted an error. These issues are recent and I presume firmware related. I am posting this to see if anyone else has had this error.
7 REPLIES 7
March411
Scarabesh, welcome to the site and sorry to hear you are having issues with your R6.
I have the same setup as you and had some issues with my 60-600mm. After speaking to Sigma support they recommendation I update the firmware on the lens. Do you have a Sigma dock and have you checked to see if there are firmware updates available.
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Tronhard
VIP
VIP
FWIW, I have been shooting with the R6II and the Sigma 60-600s for a while with absolutely no issues, but I updated my firmware to the current version before I went to mirrorless.  Like my colleague Marc, I hope that updating the firmware on the lens will resolve your issue!
It's a great lens and works brilliantly with the R5, R6 and R6II.
cheers, TREVOR
Thanks for the feedback. The lens has been on the latest firmware, it actually shipped with it, and I’ve had no issues until recently. I must have skipped that the issue also happened with an RF 14-35f4 while typing. I was in contact with Canon and was informed that error codes should end in zero. I will double check should it code again. I did format the cards before it crashed and coded but not before it was glitching, the rep said a card could be corrupted or a battery issue. I will need to drill down further and figure out if any one combo is causing it to crash or if it’s the body. I say it started after the firmware update, most logical point IMO, or could be a hardware failure that just happens to coincide with the firmware update. Thanks again.
Thanks for your response.  Well the inclusion of a second lens definitely suggests something other than that specific optic.  I would definitely consider the card and battery.   FWIW, just in case, I have the following suggestions about SD cards:
Use only Full-Size SD cards, and avoid micro-sd's with adapters they often generate errors in cameras.
I recommend reputable card makers such as SanDisc, Lexar, and Prograde, from reputable stores.  On-line deals run a risk of counterfeits.
I suggest never deleting files off your SD cards.  Instead copy the files to your computer and format the card in your camera.  This avoids cumulative errors from deleting files and and overloading the FAT table with multiple entries for each file.
I mostly use Canon batteries, but have also reliably used SmallRig and Kingma brands as well.
cheers, TREVOR
If the issue is happening with native RF glass, I would suggest resetting the camera to defaults and not making any customizations after the reset while normal operating is confirmed.
Using a freshly formatting memory card is also recommended as Trevor suggests.  For thoroughness, can you confirm for us the firmware version your lens is running.
Also, what brand lens adapter are you using with your camera please?  Canon brand or other.
March411
Scarabesh,
I did the camera firmware update to 1.4 yesterday and took several test shots with no challenges so far with the updated firmware. I purposely used third party batteries and a freshly (in camera) formatted SanDisk 128GB Extreme PRO SDXC UHS-II Memory Card.
I plan on getting out today and will do a little more testing to see if the update causes any challenges.
Marc
Windy City
Personal Gallery
Scarabesh
Hello everyone. I appreciate everyone's feedback. I had been running a third party batter grip and I noticed the screen blackout when I barely touched the battery door while trying to push the menu button a few weeks ago. I removed the grip and I haven't had the sensor error message since, but that only happened the one time. I shot an airshow last weekend without the battery grip and had some interesting things happen, like the mechanical shutter driving after I let off of the shutter release button on the first day. I might be convinced that I didn't fully release it. The second day was about 107 degrees and I had no issues with the camera other than missed focus, but that was probably due to heat distortion. The temperature warning appeared after about 2 hours switching back and forth between stills, video, and pre-capture. I believe that the grip may have contributed, but I'm not yet sure that all is well. I will keep this updated if it glitches again. I am using the canon EF-RF adapter for those wondering.
