12-05-2022
09:44 PM
08:36 AM
A few days ago i finally get it ver happy about it!! I test all lense canon mostly but when attached my rokinon sp 85mm 1.2 manual and push the shutter for taking a photo the camera froze on me I got to take the battery to make it work again, in video works great no problem only when i need it for photos, is this normal or my camera is broken? Please advice
12-05-2022 10:18 PM
Your camera is not broken if it does not work with a non-Canon lens, they are not guaranteed to work. Did you set the camera to take an image without a lens?
12-05-2022 10:54 PM
Thanks for your reply and yes I did but same results froze and have to remove the battery to get it to work again, now in my Eos R it works great no problem.
12-06-2022 07:34 AM
Are you using a Canon lens mount adapter?
Do you turn off the camera to change lenses? If not, you should do so. Turn off the camera. Mount the lens. Turn the camera back on.
12-06-2022 08:16 AM
Yes canon adapters 100% and yes off every time to replace the lenses unfortunately same results froze on me screen turn black red doc going off for ever and i have to remove the battery to make the camera work
12-06-2022 09:13 AM
Hmm. It works great in video mode, but not for photo modes, you say? That’s a new one. That sounds like a compatibility issue with the lens. I would contact Canon Support, simply because it works in one mode but not the other.
12-06-2022 04:02 PM
I talked to canon support and they say that the camera is not broken but they not guarantee that the Camara will work with a none canon lenses and that probably that specific lenses did not make it into the compatible lenses, I bit disappointed to not be able to use this lense.
12-09-2022 12:11 AM - edited 12-09-2022 12:13 AM
Even worse problem.
Brand new R6 MkII.... connected Rokinon RF 14mm AF. Canon didn't even turn on. Had to remove battery and change to Canon lens. Camera turned on....but would take 5 seconds to turn on instead of near instant as it did prior to connecting the Rokinon lens. Had to Reset Camera to bring the speed back to where it was. So....the Camera got seriously messed up in software by simply connecting the Rokinon lens.
What the?
12-09-2022 07:07 AM
You might want to check rokinon web page they got docks for your lense I believe that they will put a new firmware to the lense, also you can ask them if they are aware of this issue to make sure any update will work to make your lense compatible, good luck.
on a side note I was able to go to a near by store (district Camera) we test my lense 85mm So 1.2 and same problem the camera froze witch give me the assurance that my unit is not broken is just a compatibility issue.
01-09-2023 10:39 AM
Hey! It happens to my IRIX 11mm f/4. It just freezes and I have to take out the battery.
Do you think this could be fixed? It really bugs me out, it worked on R5, RP and R perfectly :///
