EOS R6 Image Doesn't Fill Rear Screen
tinaco
I just bought a an R6 and am working through and learning the menus.  The image on the rear screen seems to only fill 4/5's of the screen.  It seemed larger a day ago.  Have I touched the wrong menu button?
Just curious?
Thanks for any help.
Tom Heiden
6 REPLIES 6
deebatman316
What mode are you in. Full Auto doesn't display all of the mention options available. Unlike the creative zone (M, AV, Tv, P & Fv) modes.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Thank you very much for the reply.  My fault, I didn't explain this properly.  I am in FV mode (which is incredible).  The actual LCD screen display - menu or image - doesn't seem to be filling the entire LCD display screen.  Displays are centered but the media, menu or image, doesn't go corner to corner on the screen.  There is a black border around the media.  Seems like wasted real estate.
Again, Thank You !
Reset the camera to factory default. To see if that fixes the problem.
-Demetrius
Thank You
Did that correct the problem. If not I can ping an R6 owner to assist you further.
-Demetrius
My first reaction is to check P8 of the Red Menus, VF display format.  I suspect you may find that is set to Display 2, which has that effect - to get the full screen set to Display 1
cheers, TREVOR
