09-04-2025
01:16 PM
01:31 PM
Hello, I just bought my camara EOS R50 and Im having troubles when I want to see my pictures. The photo appears all black and with ? sign. Then, I transferred to my computer and make sure is .JPG and still not opening, the photo in the computer says is not compatible. Anyone know what is the problem here?
09-04-2025 08:50 PM - edited 09-04-2025 08:51 PM
Marianapvb.
That ? Mark indicates that the photo has been deleted. That's why it's not showing up in your computer either. Did you make some kind of change to your settings?
Did you format your card before you started using your camera?
Try formatting it again.
Steve Thomas
09-04-2025 10:17 PM
This sounds more like an unreadable or corrupt file. Please ensure you are using a full size SD card and not a micro card with adapter.
The card should be formatted in the camera before use. Please test with another card, formatting it first and taking some photos.
Report the results. 🙂
Marianapvb.
Steve Thomas
09-04-2025 10:17 PM
09-22-2025 10:34 PM
Thank you! I did not format the card before use. I did it now and worked, I can see all my photos 👏
09-23-2025 07:32 AM
Glad to hear it. You should be all set.
