EOS R5 windy day IBIS
johnrmoyer
Whiz
Whiz
Hello
On a windy day when multiple things are moving in different directions, it seems to me that the IBIS might get confused on the EOS R5. Even though the auto focus locks onto the eye of the bird, the image ends up soft. It appears that the bird is most in focus, but the image is still blurred. This seems to be true when there are leaves of grass or tree branches blowing around.
Is there a setting that would prevent this?
Thanks in advance.
(two attached photos are from the same day and near the same location)
Lark Sparrow at Lake Thunderbird todayLark Sparrow at Lake Thunderbird todayPied billed grebe at Lake Thunderbird todayPied billed grebe at Lake Thunderbird today
johnrmoyer
Whiz
Whiz
I am somewhat confident that I have identified the problem. I left feedback for Canon using the link on their web page.
EOS R5 with attached Drop-In Filter Mount Adapter EF-EOS R and EF 100-400mm f/4.5-5.6L IS II USM and Extender EF 2x III.
Sometimes when the camera goes to sleep and then wakes up the IBIS appears to use the wrong focal length. Turning the camera off and back on seems to fix this.
I have placed CR3 files showing an example of this problem on my web server at:
https://www.rsok.com/~jrm/raw/IMG_7509.CR3
https://www.rsok.com/~jrm/raw/IMG_7530.CR3
Both photos were made the same day not too far from each other. They were hand-held and made from an automobile window with the engine not running. It was very windy. The earlier photo seems sharper and all of the later photos that day seem to have the same type of blur.
Thanks.
Camera serial number: xxxx
John Moyer
jrm@rsok.com
13 REPLIES 13
Tintype_18
Regarding wind, are you able to use a tripod? Not always feasible in the wild.
John
I usually do not use a tripod because by the time I have it set up the bird has moved.
Thanks.
johnrmoyer
Whiz
Whiz
Thanks.
John Moyer
jrm@rsok.com
