10-18-2024
10:12 PM
09:14 AM
I thought I did everything to Set my R5 to back button focusing but now without touching any button, my camera focuses on it's own......continuously. In the custom buttons I have the shutter button control set to metering start and the AF/On control is set at metering and AF start. I must have something set wrong!!
10-18-2024 11:08 PM - edited 10-18-2024 11:09 PM
If you look in the Pink section of the menu system, Page 1, and you have continuous autofocus set to ON, turn it OFF.
If you have BBF set, also remember to set the AF Operation to SERVO if you are wanting to track moving subjects. With that setting, for static subjects, you would TAP the AF-On button; for moving ones, HOLD the AF-ON button.
10-18-2024 11:20 PM
Thank you!!!!! That worked!!
10-18-2024 11:42 PM
Glad to help. Please mark my post as a solution so others can find the answer and not ask the same question again!
Thank you!
