EOS R5 Mark II stopped sending photos to computer while tether capturing.
JBLCI1
My R5 MkII stopped sending photos to my computer while tether capturing with Lightroom Classic. LrC can still trigger the R5, and I can still manually import photos while it's tethered. The photo count flashes as though it's trying to save the image. It successfully saves the image locally on the SD but fails to send it to the computer. This issue started seemingly out of nowhere. I used the R5, tethered, the day before with no issue. I do a lot of high-volume shooting, so immediate feedback is essential for my workflow.
Troubleshooting so far:
Restarted everything, R5 Firmware updated, checked for computer and LrC updates, tried alt cables (original cables and tethering work on an R6 MkII), disabled all communication settings, reset communication settings.
EOSutility is not installed on my computer.
I know there's a popular idea that the cable is charging the camera, causing it to not send data. I haven't had an issue with this before - I am getting a dummy battery to test this theory.
Hardware - Firmware - Software
Camera: R5 MkII purchased a few months ago; firmware was 1.1.1. when issue presented itself, updated to 1.3.1 as part of troubleshooting.
Tether cables: Canon C-to-C cable that came with the body to a Tether Tools C-to-C extension cable.
Computer: MacBook M3 Pro - macOS Tahoe 26.5.1 - current version as of time of post.
LrC: 15.4.1 - current version as of time of post.
Any help here is appreciated!
20 REPLIES 20
I haven't been able to fix it yet. Will update when I do.
JBLCI1
I started using EOS Utility 3 to auto-import to LrC as a current workaround. Nothing suggested has worked to fix this issue. Currently exploring options with Adobe chat.
continuousone
Same thing happened to me. Please update this post when you do find out. Thank you for posting?
liz12345
This is the only way I could get it to work:
Problem: Latest LR was connecting but images were not actually coming through. Could work around using Utility & auto update but not tether.
Short answer, don’t update..
Solution:
Need to go back to previous version of LR, not 15.4. Images will then load into LR correctly but utility 3 must not be open when you start tether.
Utility 3 can be on computer if it’s not on when LR loads. Camera won’t connect to LR tether if UTILITY is open.
You can use utility 3 auto update option if you open it first and then don’t try to tether but auto import instead
joesmosax
I have the SAME issue. R5 mk2 connects- LR classic allows one remote fire, then nothing. The camera can fire but nothing is written to disc. Connect my mk1- works perfect. This happened after the latest update.
kckratt
I am having exactly the same experience.  Any fix found yet?
JBLCI1
Found the fix; I needed to check "Use Canon SDK for Tethering Canon Cameras" in LrC preferences.
Here are instructions for this from a Mac user. Select "Lightroom Classic" button at the top left, select the second option "Preferences..." or use the "Command + , (comma)" shortcut. In the middle of the pop-up, under the "Tether Option" section, select the box for "Use Canon SDK for Tethering Canon Cameras." Restart LrC.
Found the fix; I needed to check "Use Canon SDK for Tethering Canon Cameras" midway down LrC preferences in the "Tether Options" box.
Here are instructions for this from a Mac user. Select "Lightroom Classic" button on the top left, select the second option "Preferences..." or use the "Command + , (comma)" shortcut. In the middle of the pop-up, under the "Tether Option" box select the box for "Use Canon SDK for Tethering Canon Cameras."
Thank you, that fixed my issue!
junction10
Having same issue - except it’s not only happening with Lightroom. Haven’t checked the Lightroom setting for using Canon SDK yet but I think it really must be an OS update causing the issue… since EOS utility works for remote shooting and you say using the canon sdk mode in Lightroom works.. however, neither Helicon Remote and Tethertools Smart Shooter 5 will transfer an image to the computer once taken and switching the camera off results in “images left to save: 1” appearing on the camera LCD but they just don’t save.
I imagine helicon and Tethertools are using their own methods of tethering rather than Canon SDK, hence being broken by OS update, since both are independent to Lightroom.
