11-02-2024
01:51 PM
03:48 PM
11-02-2024 02:06 PM
Welcome to the Community.
Your post is not the first to report issues with Irix primes. They are not compatible with the RF mount, even if you are using the Canon mount adapter. I suggest that you check with Irix for any lens firmware updates.
11-25-2024 12:06 PM
I love the Irix for Astro photography. It has worked great on both of my R5 camera bodies with the Canon adapter. I recently got an R5 ii and it seems to jam the camera. The camera will not work until I remove the battery. I tried it with my Rokinon 24 mm f/1.4 and had the same problem. Works with the R5, not the R5 mark ii. Any suggestions?
11-25-2024 12:55 PM
Turn off all lens corrections.
11-25-2024 02:47 PM
I confirmed with Irix that the lens requires a firmware update to work properly with the R5m2.
11-25-2024 08:54 PM
How do you do a lens firmware update on an Irix?
11-26-2024 08:39 AM
You probably have to send it in.
