11-29-2025
05:14 PM
09:12 AM
I am trying to update the R5 MarkII firmware to v 1.2.0.
The firmware eos52-v120-mac.dmg downloads to my hard drive on a MacBook M1 okay.
But when I try transfer the unpacked file to the 512GB card by taking the small arrow on the screen and clicking on the small circle to the right it does not unpack to a fir file.
Any suggestions?
11-29-2025 07:45 PM
The .FIR file is one of the files in the .dmg which needs to be extracted or unpacked. If you don't see if on your desktop when running from the same location, open preferences for your desktop and enable the show disks check box.
Once unpacked, copy only the .FIR file to the root of your memory card. Only have one card in the camera when you perform the update. Use the quick control dial to move the cursor to ok, and press the set button to execute.
11-29-2025 07:45 PM
11-30-2025 12:14 PM
"Only have one card in the camera when you perform the update."
And I would have only the FW file on the SD. Nothing else. A FW update needs to be done exactly the way Canon instructs you to. They provide ample instructions on how to achieve it.
11-30-2025 12:26 PM
This might help - it's from a different firmware update earlier this year, but it shows you how to copy the file:
