11-12-2025 10:06 AM
The magnify button on my R5 has stopped working. I have reset both "Basic Settings" and "Other Settings" to no avail. The rear screen will enlarge using finger commands. Any suggestions short of sending it in for service?
11-12-2025 12:42 PM - edited 11-12-2025 12:44 PM
First, be sure you don't have the lock button engaged.
Next, try a business card. Gently insert a corner and rotate it around the 🔎 button. Be gentle.
You can also try a little compressed air and/or contact cleaner. Do not use anything that will leave a residue.
If this doesn't help register your camera in your MyCanon account and initiate a repair/inspection request.
MyCanon https://share.google/jzeIcCFkgOnFGXrkG
11-13-2025 09:33 AM
Thanks for the info. Unfortunately none worked. So it looks like it's off to service.
11-13-2025 10:02 AM
FYI, I reassigned the Magnify function to the Dial Function button as a work around.
