EOS R5 How to automatically zoom all photos to focus point during playback
luciano
I take photos of birds and they are often distant and small in the frame. As I view each photo, I often need to zoom into the focus point on each photo. Instead of having to zoom into each photo as scroll through photos, I'm wondering if there's a way to zoom all photos to the focus point during playback?
8 REPLIES 8
Waddizzle
Yes.  Most Canon cameras allow you to control this in the blue Playback menus.  You can define the zoom level.  You can set the “center” of the zoomed image as being a locked AF point or the center of the image.
Note, note all images will have a locked AF point.
Moderator
Moderator
Thanks for joining the conversation, luciano!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Really? I don't see how to do this with a T6S.
Canon R5.
On page 4 of the blue menu, there is a range of options but I cannot see how to zoom every image to the focus point.
I'm aware that I can magnify each image to the focus point by pressing the magnify button, but I'm after a way of avoiding even having to press this button and just show each image already zoomed into the focus point. This would allow be to rapidly scroll through images and keep the ones I need. When taking images at 20 fps, there are a lot of images to go through and I'm looking for ways to speed up the process.
I said “most cameras.”  I assume Rebels do not offer the feature.
The OP has an R5.  This is where you would set up the default playback display.
Have you tested each of the options to see how they work?
Have you tried “Actual Size (from selected pt)”?
Hi yes tried those, but I believe they only refer to what happens when magnification button pressed. Wondering if there's a way to magnify photos automatically without pressing magnification button?
I am certain that your belief is incorrect.
Are you sure you set it properly?  What shooting mode are you using?
Do you have a nearby camera shop or someone that can you look at your camera?  If it is not working for you, then I suggest you contact Canon Support for your country.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
