EOS R5 Freezing up
mxmbtm
Hey there! I am experiencing a very frustrating issue with my Canon R5, mainly when shooting video. The camera will record sometimes only for a second or two, and sometimes for half a minute, and then suddenly freeze up and need to be restarted with the clip being shot nowhere to be found. This issue recently has become so unbearable that I sometimes need to restart the camera 3-5 times to get a simple 5-second clip. To even think of recording for minutes seems impossible. Occasionally the camera will also freeze up when shooting photos stating "Err 70. An error prevented shooting. Turn the camera off and on again or re-install the battery."
- This happens with multiple memory cards (CF and SD)
- Link to the CF-Express card I currently use: https://a.co/d/9aeG9TQ
- I am using a Canon battery
- Seems to happen more often when autofocus is enabled, image is overexposed slightly (bright sky), and lens stabilization is on.
- Occurs with all lenses (Tamron 70-200 2.8, Canon RF 24 1.8, Canon EF 50 1.8)
- I have tried resetting the camera using this method: Reset camera under wrench menu 5 “Basic Settings only”, clear custom functions and custom settings under next menu (camera) 3&5. Turn camera off. Remove battery pack, memory card and lens. Hold down shutter button for 20 seconds. Put battery, memory card and lens back and turn camera back on.
If anyone can offer some help that would be greatly appreciated. Thanks in advance.
26 REPLIES 26
Greetings ,
We'd appreciate knowing what Canon says after the camera has been evaluated.  I hope the issue can be identified and resolved quickly for you
I will definitely let you know! Thanks, I hope so too!
keylanh
I am having this issue all of the sudden as well! It really messed up a live panel discussion that I was filming. Luckily I had my 6K Pro as a main wide camera but I lost about 15 min of the 1 hour shoot because the camera kept freezing.
It only seems to be happening with video recording. No such issues with photos.
Shooting on a variety of V90 and CFExpress cards from SanDisk and Lexar.
It is a very new issue and I’d love any insight you all may have!
Cameras: 2x R5, C70, 5D IV
Lenses: RF 28-70 f/2 L, RF 85 f/1.2 L, EF 11-24 f/4 L, EF 17 TSE L, EF 24 TSE L, EF 135 f/2 L, EF 70-200iii f/2.8 L, EF 100 Macro f/2.8 L
hardeepssingh
I have same issue. Using for photos only. Bought in Dec 23, First unit had purple scren issue, exchanged for new unit. This have err70 issue, re insert battery. I am using with RF 24-70 F2.8. No fix yet. Send back to get money back, not looking at repair at all Its a brand new unit.Tried every solution over the internet. No Luck.
ctrip
Same issue here. I'm using an Angelbird AV Pro SE card. It's not an overheating issue. It's very very random.
Most probably it's a faulty motherboard.
Did you get any response from Canon?
This thread has been inactive for a while and has received "me too" posts from others with different circumstances.  Some video, some images, different formats and media.  Unfortunately, the OP never followed up.  I have 4 AngelBird cards.  All have been 100% reliable, shooting video or images.  It would be helpful for anyone who is affected to start their own thread.  Include their camera model, firmware, media brand / type, lens or lenses, and any attached accessories where the behavior occurs.  Is the problem reproducible, etc
is there an update with the new card??
