EOS R5 - Fastest way to switch between "4K 50 fps" and "4K 100 fps"
SunnyG
Hello
Switching between "4K 50 fps" and "4K 100 fps" (yes, PAL) is quite some work and not handy when on a shoot.
Any idea how to switch fast without using custom modes (C1 C2 C3)?
BTW: Not using custom modes because if you switch to another custom mode, also the shutter speed, aperture and the ISO is changed to its default settings.
Thank you!
1 REPLY 1
John_Q
Hello SunnyG,
I assume that you already have the video system set to PAL in order to use these frame rates. The image quality/resolution or frame rates is not something that you can customize a button for in Movie recording like you can for still shooting, unfortunately. Using the Custom modes may be your best option.
