EOS R5 AV setting remains visible when camera is off
Kpee
I have just purchased a canon EOS R5 and note that, unlike my EOS 80D, the AV setting remains visible in the window when I switch the camera off. Can you tell me if this is correct and if it is does it deplete the battery life?
Thank you Kpee
2 REPLIES 2
This is the default behavior and expected.  My top LCD turns black with a battery inserted and the camera is shut off.  Don't worry, it doesn't affect battery life.  If you're not going to be using your camera In the next 7 days or more I'd remove the battery.  Storing your camera with a battery installed for an extended period of time is not a good practice.  Congrats on your R5.  It's quite an upgrade from your 80D which is also a great device.
This is how the R5 works -- it keeps the top LCD "running" all the time.  But don't worry about it -- monochrome LCDs like that use essentially no power.  In fact, they theoretically use no power -- they are designed as an open circuit.  There's just going to be a very tiny amount of leakage.  The internal leakage in your battery is probably way higher.
The colour LCD in your camera's main display is a completely different beast; that's a huge power hog, maybe the biggest in the camera.
