11-12-2020
10:42 PM
08:04 AM
I am mostly certain this is user error, but I can't quite diagnose it. When I record clips in 4K/120 on the EOS R5 and import them onto my Macbook pro, the clips get imported at 29.97 fps for some reason. When I record at 23.976 fps they get imported at 23.976. I've checked using mediainfo and in Premiere Pro. What am I doing wrong
12-18-2020 12:58 PM
The R5 records 120p video at 30 fps. This way it plays back at 1/4 speed.
It's shooting 120 frames per second but it's recording it at 29.97 frames per second.
11-13-2020 09:58 AM
What version of MAC OS?
How are you importing the files?
11-13-2020 10:40 AM
Do they play back at the right speed?
11-13-2020 04:29 PM
I am using 10.15.7. I've imported two different ways with the same result; EOS Utility 3 and direct transfer from a card.
Interestingly, it looks like what's showing up on my laptop is playing 4x slower, but I need to do some more data collection. If it is the expected behavior someone should have seen it. Mediainfo also says it's 29.97. All clips recorded at 23.976 or 24, show up at the correct rate and speed.
12-18-2020 12:58 PM
12-25-2020 03:30 PM
Thanks. I should have mentioned that I figured that out after playing around with speed in premiere. Wish it said so somewhere.
12-14-2023 06:25 AM
How did you figure it out?? Mines doing the same thing!!
