04-20-2023 01:29 PM
I have. EOS R10. When in aperture mode it is now pauses and says busy. It never did this before. Any advise?
04-21-2023 02:11 AM
Based on the information provided, it seems like there might be an issue with the camera's performance in aperture mode, causing it to pause and display the "busy" message.
Here are a few things you can try to troubleshoot the issue:
Check the camera's memory card. Make sure it has enough space and is not full. If it is, transfer the files to a computer and delete them from the card.
Change the aperture setting. If the issue persists, try changing the aperture setting to see if the problem is specific to a certain aperture value.
Check for firmware updates. If your camera has not been updated in a while, check for any available firmware updates on the Canon website and install them.
Try a different lens. If you have another lens available, try using it to see if the issue persists. This will help determine if the problem is with the lens or the camera itself.
If none of these steps solve the issue, it may be best to contact Canon customer support or bring the camera to a professional repair service for further assistance.
