03-08-2024
10:16 PM
08:13 AM
My Canon EOS R does not have a battery grip, however I am getting this error “Ensure a battery grip is attached securely to the camera”. I’ve tried changing multiple batteries, cleaned the battery ports, but still have this issue. I had a photoshoot in a cold area when this occurred, I’m not sure if that adds to the problem
Has anyone come across this problem, or has a fix for this?
03-09-2024 12:54 PM
Found the issue!
thank you so much for your help. I cleaned the inside of the camera one more time with a different microfiber towel, and then let the camera sit without a battery for about an hour, and this seems have fixed the issue
03-09-2024 12:27 AM
Research indicates this might be an issue with the battery door sensor. The door gets removed when you use a BG. If the door is not aligned or closing properly it might trigger the error message. The camera knows when the door is open or off. I'd carefully remove the door and inspect the area. Dirt could cause an issue too. Take a look at let us know what you find.
03-09-2024 10:20 AM
No luck
removed/realigned the door, cleaned inside the camera battery slot, and cleaned the batteries
it keeps trying to recognize that there is a BG, but none is attached
03-09-2024 11:20 AM - edited 03-09-2024 11:31 AM
Since this is a power related error, please confirm your battery (ies) are Canon brand, and that you have tested with more than one? Next step I would try is resetting the camera's main and custom settings to defaults. While I am not confident this will help, it won't hurt to try. If that doesn't work, the camera should be inspected by Canon for a hardware fault.
If you had a grip, that might help with troubleshooting:
I wish I had more to offer here. 🙁
03-09-2024 11:30 AM
Thank you for the help, but Ive checked that the batteries and they worked on a second camera and they’re also canon brand. Is there a way that you can hard reset the camera? I keep getting this error as soon as the camera turns on, and can’t get to the menu
03-09-2024 12:26 PM
Hi Matt,
Hard reset option, unfortunately not. I was hopeful you'd find the issue by removing / installing / inspecting the battery door area.
03-09-2024 12:51 PM
I do not know why you would get a battery grip message without one installed. Have you ever installed a battery grip on this camera body?
The message made me wonder if there is an issue with the battery door sensor. But, if it were an issue with the door sensor, then the camera would not turn on. In other words, if that were the issue, then you would never see an error message.
03-09-2024 12:54 PM
Found the issue!
03-09-2024 01:08 PM
Matt,
Great News!!!!
