06-06-2023 04:20 PM - edited 06-07-2023 02:21 PM
I'm trying to connect my camera to my laptop to transfer my images. This has worked with all my previous cameras (DSLR), but with this one, Windows does not display it in the file manager. It does nothing.
Yes I've looked at other posts regarding this and no it has not solved my problem.
I've tried 2 different USB-C cables, and one USB-C to USB-A cable. I've tried all the USB ports on my laptop. I've tried with a different computer running Windows 11. All these cables, ports and laptops are working fine when connecting other devices.
I don't have an SD card slot in my laptop, nor do I want to use an external card reader There's a USB-C port on this camera, so there should be a way to connect it to my laptop no? What am I missing?
Thank you.
06-08-2023 12:51 PM - edited 06-08-2023 12:52 PM
I called Canon support and they kept telling me that I needed their USB-C cable that's way too expensive, and I kept telling them that a USB-C cable is a USB-C cable, and that I tried 3 of them, and they all work with other devices but not my EOS R, but they would not let it go.
So I went to a local camera store to test the Canon IFC-100U cable that looks to me like a normal USB-C cable with two ferrite beads, and guess what? It's working!
I'm at a lost for words. I'm not an electronic expert, but apparently the Canon's USB-C cable (with its ferrite beads) is different enough from all the other USB-C cables I have, and with this one it works. So I bought it and everything is fixed. I still don't understand why thought.
Thank you all for your good suggestions!
06-07-2023 04:28 PM
Before you install the EOS Utility on your daughter's computer, try connecting the camera with the USB cable and see if you see the memory card in File Explorer.
06-08-2023 12:47 PM
I do not see anything in the file explorer. So I installed EOS Utility on my daughter's laptop and it's not working either.
06-08-2023 01:18 PM
@rmqc wrote:I called Canon support and they kept telling me that I needed their USB-C cable that's way too expensive, and I kept telling them that a USB-C cable is a USB-C cable, and that I tried 3 of them, and they all work with other devices but not my EOS R, but they would not let it go.
Great! That is good news. Ferrite beads reduce noise on the data lines.
08-13-2023 07:35 PM
I bought an Amazon Basic USB-C cable my computers don't have any problems connecting to our EOS R or RP.
It works every time.
01-03-2024 04:14 AM
Ok, I just solved this problem after hours of headaches.
In Device Manager, check the USB Root Hub connected to the USB port you've plugged your camera into. If you see an error listed, check to see what other device conflicts with the port. In my case, Spacedesk was jamming things up and all problems went away when I uninstalled the Spacedesk device driver.
To find out which USB Root Hub you're connected to, download the "USB Device Tree Viewer" freeware utility.
I hope this helps others.
01-16-2025 08:06 AM
Hi all,
I had the same problem, I was trying what everyone in here suggested but nothing worked for me until I digged a little deeper in my camera settings and found this to help. I'm on an R50 and I don't know if the menus/settings will look the same on other Canon cameras, but i guess they somewhat looks the same, try this:
Go to: Menu - Settings, page 4 (the lttle wrench) - Choose USB connection app - Photo Import/Remote Control.
Mine was set to Canon app(s) for Iphone and I had to change it to Photo Import/Remote Control. I did this together with what Wadizzle suggested and turned off all wireless commutications and bippity-boopity-boop, it worked perfect.
I hope this will help! 😊
