08-25-2025
11:09 AM
02:53 PM
Hello friends.
I have been using Canon EOS-R camera with a 26GB micro SD card.
Sometimes the click works, I can see the preview but the image shows like it saves, but when I look at the preview after the click, it does not show the image. I then took the card an put it in computer and it could still not see 216 of the 600+ images.
then I took two pictures later in the night, I could see them.
This is the second time this has happened.
08-25-2025 11:41 AM
Using micro SD cards in adapters is a recipe for disaster in these cameras. You should use the full size SD cards to avoid troubles like you are experiencing.
08-25-2025 11:41 AM
08-25-2025 11:56 AM
Thank you Brian. I will work on this surely.
