EOS R Display & Viewfinder Jittery
cascotroy
Hi All, need some help.
Recently got a EOS R, mint body condition
Firmware: 1.8.0.CF
Mode: Manual , Photomode
I noticed the view finder laggy and jittery in comparison to my RP. Went to try change the settings to Smooth, however the option "Disp. Performance" is grayed out and gives an error message "Not Available" when you try to select it. I did a settings reset as well as custom function reset, also tried updating the firmware using 1.8.0 found on Canon USA website. Still unable to gain access to the setting. Whenever you do turn the camera on, there is a little icon ("FPS") that appears bottom center  for a brief second.
Why is it my firmware in the camera say "CF" attached to it? I seen no documentation online about that. What could it be that is causing me not to be able to select Smooth setting?
My battery has two green bars when it comes to recharge performance, both are LPE6N.
4 REPLIES 4
NatalyaP
Greetings cascotroy,
Per your description, it sounds like the EOS R camera you have with you has the stop motion animation firmware installed. One of the functions that this firmware version disables is the display performance menu option on the camera that allows users to change the performance to "smooth".
You may send your camera to our facility for them to remove this firmware version and to install a standard firmware on the camera. Unfortunately, this is not something that can be done on the user's end.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
jrhoffman75
https://www.dpreview.com/news/1623284310/canon-releases-100-firmware-update-for-professional-stop-mo...
this explains it
Waddizzle
Have you purchased a used camera body?  If so, it is a best practice to fully reset the camera back to factory defaults.  You want the camera to be in a known state when you begin using it.
Thank you  Natalya, would there be a cost for this procedure for an out of warranty unit?
