EOS R Crop mode selection
HenryKalb
I am interested in a unique look of rounded images on a full frame sensor by using APC lenses. I want to be able to turn off crop mode when I mount an APC lens on a full frame camera. Please update the firmware to allow this.
15 REPLIES 15
Walt_Felix
Enthusiast
Would be helpful to share what body/lens you are referring to.
Walt Felix
https://linktr.ee/waltfelix
EOS 5D Mk IV, 90D, 400D
Canon EOS-R R body and any RF-S lense
I want to change it to "FULL"
Not sure this is possible, but you can try.  If you can't select it from the menu its likely not possible.  The camera will likely detect the crop lens and switch for you.  The camera may not allow Full setting with an APS-C lens.
That is exactly what happens. I tested it at B&H today. I'm requesting that this be changed in firmware to allow the choice. I don't believe it will ever happen for technical reasons and more so for marketing reasons. They don't want cheaper RF-S lenses used on full frame cameras. But I'm hoping they prove me wrong!
jrhoffman75
You can do it in post.
Thanks John 👍  I was about to mention this.
I think there is an editing option for adding vignetting in DPP and possibly other post editors.
This would be a lot quicker and easier than trying to capture images like this.
Tronhard
VIP
VIP
I understand why you want this, but I wouldn't hold your breath...  In the meantime, I would support the suggestion from Rick about doing this in PP.
cheers, TREVOR
