03-03-2024
06:55 PM
09:35 AM
Trying to capture night sky with time lapse and exposure times greater than 5s. The EOS M6 Mark II seems to restrict time lapse exposure time to no more than 1/8s. Is there any way around this limit?
Mike
03-03-2024 08:40 PM - edited 03-03-2024 08:42 PM
The built in interval timer in the M6 MII is a simple setup using the movie mode and this has a lot of restrictions including the 1/8s slowest shutter speed you found along with a 4K maximum resolution instead of what the sensor is capable of providing.
To do it "right", you will need the Canon TC-80N3 and the RA-E3 adapter to adapt the TC-80 control plug to the port of the M6 MII. The TC-80N3 is a very capable self timer/interval timer/long exposure timer/exposure count timer which allows you to combine its modes and it works very well.
Using this external timer/controller allows you to use all of the camera features to their fullest.
Rodger
03-03-2024 11:38 PM
Rodger,
Thanks for the quick reply.
The TC-80N3 is rather pricey at around $150. Amazon has a knockoff named "JJC TC-80N3 Intervalometer Timer Remote Shutter Release Time Lapse" for $22. Would you happen to know if this will work with the M6 Mark II when the RA-E3 adapter is used?
03-04-2024 08:58 AM
I would check the reviews and see but it should be returnable. If the company makes a variant with the plug that fits the smaller cameras directly, then you won't need the adapter cable which converts the classic 3 pin connector to a mini phone plug used by the M6 MII.
Rodger
