05-27-2025
02:49 PM
02:50 PM
I asked this question lumped together with several other questions, but was afraid it might get lost in the shuffle so I’m going to ask again.
I am looking for information specific to the EOS M model. I have seen some things online, but not specifically for my model. The user manual was of no help. I can plug my flash into the hot shoe, and turn it on, and it lights up when it’s fully charged and ready to fire. However, no matter what settings I’ve tried, and making sure I’m in a very dark closet to test this out, the flash never fires. For right now, I’m just looking for a mode with a flash with fire for every picture I take, and then I can worry about the flash firing only if it detects it’s necessary. I’ve played around with the camera, both in automatic and manual modes, and with the INFO button, I can scroll over to the lightning bolt icon, and it doesn’t have a slash through it, so it looks like it’s enabled. If anyone can give me any ideas of why it might not be working and what I can do to fix it, would be greatly appreciated,
05-28-2025 10:55 AM
I would check that you have the flash enabled to fire.
With the camera set to one of the creative modes - M/P/Tv/Av - press MENU and go to the first page in the RED menu section. At the end of the page is the option External Speedlite Control. Press SET and then the next level menu is displayed, the first entry is Flash firing, it must be set to Enable for the flash to work. Please check this as a first step.
05-30-2025 02:22 PM
Very old flashes put out very high voltage on the hot shoe. This can burn out the camera’s flash circuitry. Or the flash won’t fire at all. I would use a Canon EX series speedlite to see if it will fire. Any Canon flash ending in EX will work. Such as 220EX, 430EX III-RT & 600EX II-RT flashes will work. The in camera flash menu only works with Canon flashes. It doesn’t work with old flashes such as the old Vivitar flash or any other manual flash unit.
05-27-2025 05:03 PM
What model flash are you using and what mode are you using.
05-28-2025 10:55 AM
05-30-2025 02:03 PM
Hi, thank you so much for this suggestion. It turns out it was set to DISABLED, but even after I enabled it, the flash still doesn’t fire, whether I am in manual or automatic modes,. do you have any other suggestions?
05-30-2025 02:05 PM
Hi, and thanks for your response. I have a very old Vivitar 2800 flash. There are a couple of different settings on it as far as selecting a shooting distance, but that’s really it. As I said, it fully charges up, and I could press the test button on the flash, and it will fire. it just doesn’t fire when I press the shutter button on the camera. I would think that most flash are standard, and if it fits into the hot tub, you’d think it would work. if you have any suggestions, other than what the other gentleman responded with already, please let me know.
05-30-2025 02:07 PM
I forgot to answer your other question. I’ve tried this on both automatic and manual modes, with a shutter speed of 1/60 of a second in manual mode
05-30-2025 02:12 PM
I just noticed one other thing when playing around with the speed lite sub menu that you told me about. I went into the flash function settings, and it says “this menu cannot be displayed. Incompatible flash or flash’s power is turned off.” I think this answers my question that my flash must be incompatible. But when I go online to try to find a new flash, how would I know whether what I’m buying is compatible or not?
05-30-2025 02:22 PM
05-30-2025 10:46 PM
Thanks. I hope I didn’t damage the flash circuit by trying that old flash for a while. So you’re saying that a flash that may not be a Canon brand, but is referred to as “speedlite” and claims it’s compatible with Canon, may not work with the menus, but i’m wondering if they will work at all. I was looking for a relatively compact flash unit, which I know isn’t going to light up a large dark room, and the only ones I saw from Canon were rather large and just about as big as the camera itself.
05-31-2025 09:30 AM
Old Vivitar flashes were know to have very high trigger voltages and prone to destroying camera electronics. Most modern cameras have protection against such voltages, but it means the flash will not fire.
I suggest that you try a Canon Speedlite such as the Speedlite EL-100 or Speedlite 430EX III-RT on your camera both as a test to make sure the camera is still working and able to fire a flash, plus these two units will give you an idea of the balance of them with your camera.
