05-04-2023 01:36 PM
Hello ,
I have EOS M50 I purchased December 2020 , have always used wired (dummy) power source, lately camera is cutting off in about 30 minutes of streaming , the only difference is I using HDMI going into Blackmagic ATEM mini pro , when camera cuts off there is a flashing green light on top right side of camera that I have never seen flashing before, Why is camera shutting off?
Thanks for all your help
05-07-2023 01:02 AM
Hi cotcm2000,
In the camera menu there will be an option labeled [Auto Power Off]. I would recommend checking those settings to make sure they are disabled. It sounds like you mentioned you had made a change to your streaming setup. If you were using the EOS Webcam Utility prior, that software managed this function for you so it may not have appeared until that change was made.
05-07-2023 10:37 PM
Thanks, all the power saving settings are off, I am using HDMI cable into Blackmagic Atem Mini Pro, I was told only USB cable connection can override the shut off feature when using the utility, my understanding the EOS utility only works with USB. I am looking for a way for the camera to stay on when using HDMI cable (the ATEM doesn’t accept USB connections.)
05-08-2023 10:23 AM
"... I using HDMI going into Blackmagic ATEM mini pro ..."
My guess without further info is the M50 is getting too hot. It has a safety shut down.
05-08-2023 12:53 PM
The M50 does not provide clean HDMI output. I believe that the M50 Mark II does. There is no way to make the camera do what it was not designed to do.
05-08-2023 03:10 PM
To my amazment, You can get clean HDMI, I just hd a Canon tec tell me this last month, I found out how to c=get a Clean HDMI by pushing buttons and by accident I got a clean HDMI
05-08-2023 05:41 PM
Cameras that support clean HDMI have 2 different outputs. They have a separate output for the LCD screen and the HDMI port. The EOS M50 does NOT have the hardware to support this feature. You simply can't add Clean HDMI out via software its NOT possible. As @Waddizzle pointed you are NOT using the camera as it was designed to be used. Your camera may be shutting down on overheat protection.
