12-31-2023 06:29 PM
The 90D online manual indicates auto focus bracketing is available (pg 255). But I can’t find it in my shooting menus. Firmware Ver. 1. 1. 1. Where is it? Is it available?
01-01-2024 12:39 AM
That was my problem. I had not pressed the Start button. Thanks. And Happy New Year!
12-31-2023 06:36 PM
Hi and welcome to the forum:
What mode are you shooting in, and what lens are you using please?
12-31-2023 07:36 PM
My first attempt I had an 85mm f/1.2. Av mode. In the manual it lists some compatible lens. I put the 18-135mm f/3.5-5.6 lens on. It was in the list. Online Advanced User Guide pg 255-257.
12-31-2023 07:40 PM
Thanks for your response. Was the 18-135 the STM or USM version please?
12-31-2023 09:14 PM
USM.
Happy New Year!
12-31-2023 09:17 PM
Then the lens compatibility on that lens should not be an issue.
12-31-2023 08:12 PM - edited 12-31-2023 08:13 PM
Sorry if this is a stupid question, but are you in live view mode when you are looking for Focus Bracketing in the menus?
Newton
12-31-2023 09:17 PM
The menu list doesn’t change if Live View is enabled or disabled.
12-31-2023 09:47 PM - edited 12-31-2023 09:51 PM
If I'm not mistaken, and I very well could be because I don't own the 90D (I have done some research though), that menu toggle only activates/deactivates the Stop/Start button. When set to "Enable", it allows you to go to "Live view" when the Start button is pressed. You will then hear the mirror flip up.
It may be the case that the Depth compositing menu won't be available until you press the Start button to officially be in Live view. But, that's just a guess.
FWIW, I do a lot of Depth compositing with my R's, in camera, and DSLR's using dedicated software and although some lenses are better suited for it, I've yet to find one that would not allow compositing to be attempted.
Newton
01-01-2024 12:39 AM
