EOS 90D Vertical shots underexposed
Ramsden
Whiz
Hi folks
I had a strange occurence yesterday afternoon, here in the North of England.
EOS90D with a new 100mm Macro attached. I was shooting trains crossing a viaduct that was built around 1850 - so quite atmospheric.
Camera set on AI servo, High Speed continuos, AF large zone and partial metering. White balance set to Shade (7000k). Tripod set up so I could pan the 200 meter track.
I appreciate that this wasnt the ideal lens for this composition. But, after getting a few shots of the viaduct to get line and focus set up; I had a reminder from a book I'd just read, to try and use vertical shots more often, and given the height of the viaduct this made sense. So 5 mins before the next train, switched camera to vertical, and took about 12 shots as the train crossed.
When I got home and downloaded the photos, all the vertical shots were black (under exposed?)
So what happened?
My only thought was that I didnt alter the 'tulip hood' for vertical and wondered if that would significantly alter the light?
Any explanations, advice, as always welcome.
Ramsden
14 REPLIES 14
Hi
I haven't covered the view finder, and wasn't aware of that procedure. Could you please explain?
In this particular situation, i was quite literally wading through an old overgrown woodland, so it was easier to use the screen.
You can configure it to prevent having your settings changed by inadvertent dial movement.
The correct hood for the EF 100mm f/2.8 Macro USM, which I have, is a Canon ET-67, or a clone (I have a JJC version). It is not a tulip hood. It's a straight tube 3" long. There's also another Canon 100mm lens, the EF 100mm f/2.8L Macro USM, which uses an ET-73 hood.
The way to see what hood Canon designed for a lens is to look in the Canon lens manual, which you can download. I have the manuals for all of my lenses. They contain a lot of good info.
When you are using a remote release on a tripod and your eye is away from the viewfinder, stray light can enter the camera and influence the exposure. Canon provides a cover attached to the strap that you can use to cover the eyepiece so no light gets in.
This is not an issue when using live view.
Hi John
Thanks for that link. I have now updated the features that are locked. Another step on my learning curve with the EOS90D.
I had mistakenly thought that when my external lock switch was on, I was relatively safe.
Regards
Ramsden
