EOS 90D Camera sensor scratches
Sadia
Hello,
I recently returned from an African safari and needed to clean my lens and camera body. I did everything fine, but once I opened the camera cap and looked at the sensor, I was shocked to see so many scratches (photo attached)! Even though my pictures came out just fine, I was curious to examine (search for spots in the image) if there were any marks on the white paper photo. I checked out some videos on how to do a white paper test to check for spots in the sensor. The white paper photo has no mark on it that I can see (attached).
I'm wondering if the scratches are common for DSLR cameras. I bought the Canon 90D last year, and it has been great so far. Please let me know if this is something concerning.
Thank you!
DSLR sensorDSLR sensorwhite paper testwhite paper test
24 REPLIES 24
Understood😀. If it’s just dust you could try blowing it off or using the method Rick mentioned. It is hard to tell from the image, but I have never seen dust on the mirror look like you posted. The reason I asked if anyone had been inside the mirror box is that if someone tried cleaning and scratched the mirror it could look like that depending on the angle of the light. But, if no one had been in to clean then I think you should rule out that it could be fungus. Fungus can spread into your lenses as well.
If you aren’t comfortable trying to clean it maybe you have a local specialty camera shop or even a camera club where someone could advise you.
Ultimately you could send to Canon for a clean and adjust. That might be a good idea after returning from a safari.
It is not dust - I'm sure of that. It looks more like scratches because it stayed as it is even after some air puffs.
No one touches my camera gear. I have not had anyone cleaned it. Today was the first time I tried cleaning.
Once I accidentally changed the lens once without turning the camera switch off. It was outside in a park, the weather/temperature was nice and almost no humidity. Do you think that might be a reason for this? I will check with Canon support when I'm back in the US.
Thanks again!
“Once I accidentally changed the lens once without turning the camera switch off. It was outside in a park, the weather/temperature was nice and almost no humidity. Do you think that might be a reason for this?”
No that did not damage anything.
EOS 1DX and many lenses.
ebiggs1
You do need a pro to clean it and Canon is the best service people.
I would hope that it is dust.  It looks more like something hit it, to me.
Definitely agree that it's worth that Ernie.  Not only will it mean the mirror is assessed and cleaned, but the sensor and interior should get a good cleaning too.  If there is other dust or material in there it reduced the risk of it getting on the sensor and damaging that.
cheers, TREVOR
amfoto1
First of all, that is NOT your sensor.
That's the mirror which reflects the image to your viewfinder. Anything on that mirror will have NO EFFECT on images. The image sensor is behind a closed shutter, which itself is behind that mirror. When you take a photo that mirror flips up out of the way and seals off light coming in through the viewfinder, then the shutter opens to reveal the sensor and take the image, after which the shutter closes and the mirror drops back down. All this happens in a fraction of a second.
You might see those marks when looking through the viewfinder, but they're merely a nuisance. They likely aren't scratches, but just "smears" of something.
I DO NOT recommend you try to clean them yourself. The mirror is front-surfaced and delicate, with a semi-transparent patch (for the autofocus system). It is easy to damage and end up needing expensive repair... just to avoid a minor nuisance? Not worth it! Leave it alone and have the camera professionally cleaned sometime (perhaps when the sensor also needs cleaning).
Absolutely NEVER, EVER use common cotton buds ("Q-tips") inside a camera! Those shed tiny cotton fibers that can get into camera mechanisms and jam them. There are specialized lint free swabs for this sort of cleaning.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
jaewoosong
Rising Star
Rising Star
If you don't know what you are doing, send it to Canon for cleaning as others have mentioned.  However, if your camera is out of warranty, you'll have to pay shipping and cleaning service (last time I did this costed me about $80 all together, $30 shipping + $50 cleaning, but they replaced the focusing screen as part of the dust cleaning).  That was years ago and I'm not sure what the current cost for sensor cleaning is now.  That was $80 because I tried cleaning my focusing screen (bad idea, don't touch focusing screen at all).
but...
sensor swap + 2 drops of sensor cleaning fluid and 4 passes with light pressure (swipe down left, swipt down right, flip swab, repeat left/right swap) and you have a clean mirror.
cleaning mirrorcleaning mirror
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
What "air puffer" are you using?  Is it like canned air spray or a manual bulb you have to squeeze?  When I looked at the picture, it looked like some liquid that was pushed with a blast of air.  Canned air has liquid propellant that can deposit some liquid on the mirror surface and the blast of air can spread that liquid around on the surface.  This can happen when people tilt the canned air duster sideways or upside down, allowing some of the compressed liquid to be release with the gas.  The only blower you should be using is a manual bulb blower inside your camera.
never use canned air blowernever use canned air blower
-jaewoo
I used the manual bulb. I watched several videos before cleaning and most videos warned not to use the canned air spray.
Thank you!
Friends and Family
