EOS 90D Autofocus Issues with EF 100-400mm L IS II USM
canon_eos_90D
I recently bought a Canon EOS 90D body.
Unfortunately I'm encountering focus issues when using the body with the Canon 100-400mm L IS II lens.
When I'm trying to focus (using OVF) on an object (like a race car for instance) that's coming towards to me, the camera/lens won't focus.
The settings on my camera are: Autofocus > AI Servo, shutterspeed: 1/1000 - 1/2000. Normally those shutterspeeds should deliver me a sharp picture. But that's not the case.
When I attach the lens to a Canon 6D or 5D Mark IV I don't have any problems at all; the focus issues don't happen with those two bodies.
I know when a subject moves closer to or further away of the camera, the sensor can have some difficulties in focussing. But with the fast shutter speeds I should get sharp images, which is not happening with the 90D body.
Anyone an idea how I can solve this issue?
36 REPLIES 36
ebiggs1
Perhaps it does I never noticed it and I never turn IS off. I have not seen that article either.
I don’t even turn IS off on a tripod and never seen it hurt/help either.
EOS 1DX and many lenses.
The info in this article is the same as was on the Canon site.
Should You Turn Off "IS" When Using Action-Stopping Shutter Speeds? (the-digital-picture.com)
As far as I am concerned they can remove the IS on/off switch!
steinr98
U-tube, Marvin the Mavin a great video series on the 90D!
Sports/wildlife settings- (by Marvin)
AV setting - set apature, Higher ISO, Watch your speed due to lighting- up ISO if needed to get 1/1500 to 1/2000 speed. You have to watch this!
Manual setting - set speed, 1/1500 to 1/2000, set apature, set ISO to AUTO, for moving objects.
Set - AL servo, Hi speed shots Not single shots, shoot in raw or can shoot jagged L jpeg if don't want to process but raw is much better(better quality).  hi speed shutter gives you a better chance of getting one or more good shots.
Orange tab in the menu: C Fn II - #1 set to -1, or -2 to lock on focus(try best for you),  #2 set to +1 if object does not change direction ( a small bird goes every where), #12 set to off or disable-90D works better without face dection( a known fact!).
I have used these setting and they work great on flocks of birds moving in one direction!!
Give it a try as you have nothing to lose.  You do have to keep the ISO up on the 90D!!  ONe other point that was made earlier, if there is a lack of contrast the 90D has a very hard time focusing period!!!
Try a tripod to make sure photos are sharp to begin with, or you may need Micro focucing adjustment as mentioned earlier!!!
Use  a target or a glossy printed page from a magazine as a trial for sharpness at a good distance.
Good Luck!
Good Luck!
Good info!
I suspect that you are referring to YouTuber Michael the Maven.  What a weird name.  I suspect that the OP is already familiar with his YouTube channel, which is probably half the problem.
YouTube - Micheal the Maven - 90D Wildlife Setup
Kuriachen
I am having similar issues but with a Tamron Lens. When I use the lens in a Full frame camera body, it works like a charm but on my 90D there are two issues. Focussing and incase I get a shot, the image isnt sharp. Tamaron says its a body problem, Canon says its a lens problem. So I am stuck with a useless kit for now.
If you have a problem with your camera. Please make a NEW forum. Commenting in an old one can cause confusion.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
