EOS 90D Adjustment Wheel Has Stopped Working
TheSlideJob
In may I purchased a new eos 90D. Recently the adjustment wheel on top, by the shutter release, has stopped working. Ive tried blowing it out with canned air with no luck. Any suggestions?
5 REPLIES 5
jrhoffman75
If you purchased it in May 2022 from an authorized Canon dealer it should be under warranty. Contact Canon at 1–800-OK-CANON to arrange a repair.
ebiggs1
"Ive tried blowing it out with canned air with no luck. Any suggestions?"
Any suggestions, yes, do as John advises. Don't mess with it.
EOS 1DX and many lenses.
normadel
What does "not working mean"? Is it clicking as you turn it but nothing happens, or is it skipping/turning freely with no clicking at all?
I ask because I fixed someone's throwaway 50D with the latter situation. The problem was the rubber tire around the wheel was slipping. Found this out searching the Web. Solution was to lift the tire and carefully put a couple of small drops of glue between tire and wheel. The camea has worked beautifully ever since.
Meaning the shutter speed doesn't change when you turn it. Canon is replacing the camera under warranty.
Now that's service 👍
Friends and Family
