07-23-2023 03:18 AM - last edited on 07-23-2023 08:48 AM by James_C
I have a Canon EOS 80 and seems every other picture I take is blurry. I wander if it’s the lens that I have. Any suggestions to what is the best lens to use for up close pictures? I am trying to capture the subject clear and the background blurry
thank u for your help
07-23-2023 05:54 AM
If it is the EF 135mm f2L then you would want to be using a low number f/stop to have minimum depth of field.
Depth of field is defined as how much of the image in front of and behind your subject will appear sharp.
Understanding Depth of Field - A Beginner's Guide (photographylife.com)
07-23-2023 09:04 AM
I agree with John. A higher shutter speed will cancel out motion blur. The EF 135mm F/2L USM lens is unstabilized. If you're taking pictures inside watch how low your shutter speed gets. If it gets too low camera shake will be visible in your pictures.
07-24-2023 05:42 PM
I really feel I need to get another lens but for now I will have to use what I have. Thank u kindly
Wilma
07-23-2023 05:08 PM - edited 07-23-2023 05:09 PM
How do you hold your camera when you shoot? If you hold it like a cell phone: at arms' length looking through the LCD, you will be far more prone to camera shake, especially with a telephoto lens.
If you are using this method, I strongly suggest you try the method below:
07-24-2023 05:44 PM
I dislike the lens i have and I have to get another one soon I hold my camera like the picture but i am at a loss here lately
